Help me friends i have openbox s9 hd orignal box.my prb is my box reboot after 2 minutes or less 1.upload a stable firmware or link me.i early have 5-01-2012 firmware.first i factory default also.what hapening pls help.
Reboot issue.
the reboot issue with 28.2e on the open box was 'supposedly' resolved mid 2011 so i can't understand why you are getting reboot problem with the f/w your using, the odd channel maybe, but not every scrambled one... unless you are on a different sat. i would try a different f/w make sure you factory reset.If it isn't broke, don't try fixin it..!!!
Thanks m8 for help me.how i factory reset?i only factory default to my box.Advise me wich f/w i use which is stable.the reboot issue with 28.2e on the open box was 'supposedly' resolved mid 2011 so i can't understand why you are getting reboot problem with the f/w your using, the odd channel maybe, but not every scrambled one... unless you are on a different sat. i would try a different f/w make sure you factory reset.Comment
Factory default same.. i use september firmware on 3 boxes and they are spot on. Not really tried any newer as there is nothing worth changing for as yet
. I have already uploaded my f/w on ere somewhere so i.ll try and find it.
post number 18
Which sat is causing the reboot. Also do you have a card in the box?If it isn't broke, don't try fixin it..!!!
I think its interdo related card problem.. only certain firmware will work with this card... you will have to look through firmware discriptions to see which works.. im not 100% certain so
could someone just verify that.If it isn't broke, don't try fixin it..!!!
M8 i remove the card but still that causing
rebooting.
Link me september firmware and see what happen to my box.
reguards'
bobyxxx.Comment
