mac address
  • walkaton
    • May 2011
    • 67
    mac address
    Hi all
    I've got a couple of s11's clones (not what I wanted) and would like to know, how if possible to change the mac address
  • krussell
    • Jan 2012
    • 12
    You can not change mac
    • walkaton
      • May 2011
      • 67
      If you are saying no mac address can be changed well they can be. dreambox has a script called patchme. And but for an unknown username I can not even try telnet to start with
      • slugworth
        • Nov 2011
        • 1064
        you can't telnet into the openbox
        • walkaton
          • May 2011
          • 67
          you're right I read that somewhere. It would be nice to have a patch to alter the mac address.
          • slugworth
            • Nov 2011
            • 1064
            eeprom
            I never searched for an eeprom,I assumed with a 4meg flash it wasn't needed.
            Old s10 had a separate ethernet board,maybe that had one?
            The LAN9220 can optionally load its MAC address from an external serial EEPROM. If a properly configured EEPROM is detected by the LAN9220 at power-up, hard reset or soft reset, the ADDRH and ADDRL registers will be loaded with the contents of the EEPROM. If a properly configured EEPROM is not detected, it is the responsibility of the host LAN Driver to set the IEEE addresses.
            The LAN9220 EEPROM controller also allows the host system to read, write and erase the contents of the Serial EEPROM. The EEPROM controller supports most ***8220;93C46***8221; type EEPROMs configured for 128 x 8-bit operation
            If the s10 had an eeprom with the mac it could probably be changed with a simple programmer.
            • walkaton
              • May 2011
              • 67
              yes thats being done right now. the supplier that supplied these boxes suggested that on my next purchase go for s10's which would then have unique mac address.
              So from what you're saying the network card (which I informed the supplier was faulty) is the problem which is tied to the mac address.
              I will be passing on the quote above to supplier to try to rectify this issue.
              • dansk
                • Dec 2011
                • 8
                sorry for my ignorance but, what happens if you have two or more boxes with the same MAC?
                thanks.
                • walkaton
                  • May 2011
                  • 67
                  thanks.
                  picture will freeze. Freezing alternating from box to box
                  • walkaton
                    • May 2011
                    • 67
                    slugworth I am viewing hex file for the box. line 4720 is that where the mac address is?
                    • slugworth
                      • Nov 2011
                      • 1064
                      openbox firmware is encrypted/compressed,so I don't know what you are viewing.The mac address would never be in firmware,or everyone would have the same.
