changing channels for your region
  • duckettdynamo
    • Feb 2012
    • 11
    how do i change a channel in my list from ie: bbc london to bbc yorks.bbc london is saved in favourites and i want to replace with bbc yorks my region.
    my downloaded manual with pictures seems to have a different menu set up.
    thanks in advance...
  • Shadwell72
    • Dec 2010
    • 17
    Can edit channels by using Dreambox edit !
    • duckettdynamo
      • Feb 2012
      • 11
      edit channel yes, but i still won't get the relevant regional channel to view in my favourite list will i?
      wifes going nuts watching bbc in irish region and she just wants it in the yorkshire region.
      thanks for any input it's much appreciated
      • Shady
        Shite Link King
        • Dec 2010
        • 6404
        bbc yorkshire will be in all satellite section of scan..
        DEPENDING ON FIRMWARE, it will be,
        MENU > CHANNEL LIST >scroll to Eurobird 1 and Astra > scroll to bbc yorkshire > press FAV button so FAV tab lifts up, then press ok whilst bbc yorkshire is highlighted.
        Fav list will come up, select section you want it in, and press ok.
        • duckettdynamo
          • Feb 2012
          • 11
          i go to menu>edit channel>channel edit and scroll to bbc yorks when i press fav button nothing happens i can press ok and it highlights the channel. the red button says group and when pressed brings up a list of all,favourite,satellite,providers,a-z. i scrolled to fav and selected the right channel but nothing happens.
          i have even gone to the right hand side of edit channel were move ,lock delete are but still nothing.
          i can't seems to put a blue icon with a loveheart for fav.
          cheers in advance peeps.
          • andy4
            • 1125
            will try this as some n00b put me itv cen in instead of itv nw
            WIGAN ATH the BLUE BRAZILIANS
            DWSTADIUM the theatre of SCREAMS
            <<<<--------if i've been helpful hit the Thanks button
            • DW190
              The easiest way to find and sort a channel is to press ok on any channel then press the green button and selectEurobird 1 & Astra hit ok on any channel till the screen is without menus.
              Now press the find button and enter BBC then press blue and scroll down the list till you find the channel you want hit ok and ok again so the channel is visible (if its not visible use the find process again and see if there is more than one channel to choose from)
              Now you have your channel and want to put it in favourites. While on the channel hit menu, TV channel list, then press the favourite button, the fav icon at the top will pop up. Press ok and you will get the favourites list, scroll to the one you wish to place it in and ok to tick the side.
              Exit until your prompted to save and hit yes. Exit out.
              Your channel will now be in the fav you selected. Select it in your fav and you can go into the menu, TV channel list again and instead of hitting the fav button hit the yellow move button, press ok to tick and move to the desired position deselect and exit out.
              After all that you will realsie how much time is spent by people making channel lists and why they expect to be thanked.
              Its a ~~~~ing nightmare.
