Openbox setup guide
  • Briazy
    • Apr 2013
    #121
    I had the same trouble yesterday, I resolved the problem by entering the code manually.
    Hope this helps.
    • Barnzey81
      • Apr 2013
      • 23
      #122
      Hi everyone. I'm a newcomer to this Skybox business too, and I've searched this site high and low gathering all the info I can to start from scratch. I've read the 'Setup guide', but I'm still struggling with a few things. Can someone tell me what 'an image file (.abs)' is please?
      • mahrkpat
        • Jun 2012
        • 510
        #123
        The image file is commonly known as the firmware when you see post about updating firmware you are updating the image file maybe a fix or added extra, you will notice firmware files are in .abs format.
        • Barnzey81
          • Apr 2013
          • 23
          #124
          Ah right, cheers. I've only just bought the box, so can I assume that I don't need to update the firmware? It's an F5... Thanks mate.
          • mahrkpat
            • Jun 2012
            • 510
            #125
            If your youtube, weather app don't work then you will have to reflash to newer firmware.
            • Barnzey81
              • Apr 2013
              • 23
              #126
              Thanx for your help mate. HOPEFULLY I'll be able to set this badboy up! I THINK I've got all the 'components', it's the putting them all together that kills me!
              • dazandy
                • Apr 2013
                #127
                can anyone tell me any info about the f5 boxes please?
                • Barnzey81
                  • Apr 2013
                  • 23
                  #128
                  Originally posted by somebodyuknow
                  I'm following the steps of the guide on Sky F3 but at step 13: On top line select 'Eurobird 1 & Astra'
                  I don't have the Eurobird 1 & Astra option.. anyone help me with this?
                  Alright guys, I've got this exact problem. I've followed the setup guide to the letter (until 'Eurobird 1 & Astra'), but this isn't an option; only '(1/1) Sky UK' is available to choose. PLEEEASE help!
                  • Hadron
                    • 2102
                    #129
                    "Eurobird 1 & Astra" means 28.2/28.5e. The same satellites that S l y UK broadcast from.
                    • k87622
                      • Apr 2013
                      • 8
                      #130
                      Hi Guys. I have just got an F5 box. I have read the guide off the website and I don't understand the cline setup. I have followed the guide step by step but it says "select network>select Ccam client setup" Here is where I am getting stuck as there is no Ccam Client setup option on my F5? Can anybody help or point me in the right direction? Thanks in advance!
                      • mahrkpat
                        • Jun 2012
                        • 510
                        #131
                        On your remote press menu then network settings press 6666 on remote to reveal secret menu.
                        • k87622
                          • Apr 2013
                          • 8
                          #132
                          thanks for the help mahrkpat. I have tried your suggestion but I cant get into a secret menu? It does nothing? Also I am only getting Eutelsat in the satellite list? I have flashed the box using the instructions provided in the tutorial. That seemed to be easy with the guide. It wont let me load a file for the channel list either? Just sticks on abs file? Is it screwed now or am I missing something?? Thanks in advance! Ok update, I am an ass as I flashed with the old 2012 version of the F5 firmware. It wasn't happy! Flashed with the correct file and it is much happier. Managed to load AJ's channel list so a big thanks to him also. Still cant get into secret menu? And I am having trouble viewing some channels? can anybody please help and thanks to those who have helped me so far. After flashing I can now get into secret menu but I don't know what to do next? It shows a few setup options but what do I need to make it work? Am I being a bit thick? Will somebody PM me and put me out of my misery please I am stumped. Thanks,
                          • k87622
                            • Apr 2013
                            • 8
                            #133
                            Hi guys! I think there are some pages missing from the guide?? It says jump to step 27? and there isn't one? Where do I get sealion? and how do I set up one of the cams in the hidden menu? thanks
                            • Aletank
                              • Jul 2013
                              • 51
                              #134
                              Hi guys - Could you just confirm I have got the Set Up Process right & in the right order - 1. Buy a Skybox with the latest "You tube" Firmware. 2. Install Gift . 3. Install Channel List (AJ's etc) Then I'm all good ?
                              • Hadron
                                • 2102
                                #135
                                You might as well install a channel list first, as soon as you get the box. Then you can check that the box is working OK on FTA channels, before the magic happens.
