no network menu option on my openbox. any suggestions. cannot install cccam.cfg HELP!
  • kaisar1
    • Aug 2009
    • 462
    hi, just bought openbox s12 however having difficulty installing cccam.cfg. i got cline and everything. i tried to follow tutorial from this site but some of the options from the box for eg network menu are missing.
    CLINE SETUP
    1: Go back to main menu
    2: Select Network
    3: Select "CCcam Client Setup"
    4: If you have a cccam.cfg on your usb, select 'Update files by usb' if not, jump to number 27
    5: On new window, highlight 'CCcam.cfg', press green button on remote (ADD). This will place a tick by it, the press yellow button on remote (READ)
    6: Once finished, select 'Manage Config Files' and on new window select cccam.cfg again
    7: A new page comes up with your cline on it, press green button on remote to make it active (tick should appear by it) Exit out of all menus to tv and select a pay channel.. it should clear, if not go back into menu, select Network, then 'Network Setup', and turn DHCP 'off' by using arrow keys and then hitting apply.
    8: if channel still doesnt clear, reboot box and router by unplugging both from power and plugging back in (router first)
    9: for those who didnt create a cccam.cfg on their usb, you can add it manually..
    a] instead of update by usb on ccccam client setup, go directly to Manage Config Files and select CCcam.cfg from new window
    b] Press Blue button on remote
    c] your cline will look something like this>>> C: example.cline.org 12000 user pass
    d] ON add cline window, leave Protocol as CCcam
    e] Host: here you would enter example.cline.org portion of your cline using remote number buttons like you was sending a text
    f] Port: here you put 12000
    g] User, write 'user' here
    f: Password, write 'pass' here
    g] Press ok and go up to instruction number 7 OF CLINE SETUP
    the section in red is where im stuck as theres no network option in the menu. help please. ty
  • tony2803
    • 266
    CLINE SETUP
    2: Select Network
    a friend of mine had a similar problem,he just reflashed the box and all was well,but i would consider first to return box to your supplier so as not to void any warranty..
    • slugworth
      • Nov 2011
      • 1064
      6666 on remote to get the network tab
      • kaisar1
        • Aug 2009
        • 462
        just found out how find network menu.
        1- menu
        2- then enter 6666
        • kaisar1
          • Aug 2009
          • 462
          do i need to install cams or anything else?
          any help. my clines i think expired and says offline.
          • Shady
            Shite Link King
            • Dec 2010
            • 6404
            try turning dhcp off in network settings.
            also nice to see you using the guide.. but not thanking the author.. nice one
            • kaisar1
              • Aug 2009
              • 462
              sorry about that. file downloaded does not mention name of author anywhere. forgot to thank when i downloaded.
              • Shady
                Shite Link King
                • Dec 2010
                • 6404
                hmmm
                Little guide i made
                might be a clue there
