openbox s11 mgcamd problem
  • asad5150
    • Oct 2008
    • 185
    hello i have a line from a server i used to have a dreambox but the line doesnt work with cccam it just works with mgcamd. iv put the line into the openbox s11 manually and with usb but it still doesnt work. can someone help me out plz. thanks
  • DW190
    Did you put it in the "newcamd.list".
    • asad5150
      • Oct 2008
      • 185
      yh it even displays the line but it doesnt work. i dont know i may have the wrong firmware or summat
      • DW190
        Have you set the DHCP to ON in the Network Set Up?
        Try rebooting your router. After two minutes reboot your box.
        • asad5150
          • Oct 2008
          • 185
          iv done all that mate still no luck
          • DW190
            Do you know if the box is going online. You can check this by logging into your router or have a look where the ethernet plugs into your box and see if the lights at each side of the socket are lighting.
            • asad5150
              • Oct 2008
              • 185
              yh iv checked that too it says that the box is attached to the router. i got a testline of another guy and put it in cccam and it works it just that mgcamd isnt working
              • DW190
                You could try converting the line from mg to CC.
                Remove CWS = server
                Replace with C: server or N: server
                Put in CCcam
