AJ's Sky UK Channel List **Discussion** Thread
  • xtreme09
    • Jun 2011
    • 4
    #2971
    anybody got a channel list for skybox a6.
    Or OPENBOX A6
    Help would be highly appreciated
    Rehards
    • mark5211
      • Feb 2013
      #2972
      Originally posted by badboynads
      Having issues with some channels not working - Sky 1, Sky Sports 2, Sky Sports 5 with the latest update.
      Please can you update the channel list and frequencies.
      Thanks for all your hard work.
      I'm having the same problem on two boxes, updated the firmware, deleted all the channels and re-installed but no Sky 1, Sky Sports 2 or Sky Sports 5
      • hkphooey
        • Apr 2010
        • 232
        #2973
        Im having trouble with sports 1 also please can anyone help please
        • joe516
          • 1000
          #2974
          sports 1 on 12.148 h 27.499 ok 4 me m8
          information given is to be used for educational purposes only
          Don't Forget To Say Thanks If You Like My Post
          IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
          If It Ain't Broke Don't Fix It
          • Diesel67
            • Mar 2014
            • 13
            #2975
            just a little note would the f5s channel list work on a v8s box please
            • mark5211
              • Feb 2013
              #2976
              Sky 1, SS1 and SS5 working again today, but Setanta Ireland, Setanta 1 and Premier now showing no signal.
              • R0BINH00D
                • Sep 2014
                • 5
                #2977
                Mark..... I had this problem but its all sorted thanks to the "no signal fix" that I was told about and got some for my boxes on ebay ever since never had any "no signal" messages just search -----> SKYBOX F3 F4 F5 AND F3S - OPENBOX S9 S10 S11 NO SIGNAL FIX
                hope this helps like it did me
                • mark5211
                  • Feb 2013
                  #2978
                  Ill take a look at those thanks, its all working again today so it seems pretty intermittent.
                  • DeejayAJ
                    • Feb 2012
                    • 402
                    #2979
                    New update here.
                    • lupin123
                      • Dec 2012
                      #2980
                      Thanks works wonders much appreciated. my sky sport 5 will not work or struggles but fine on vu ultimo and 500 s and segestions much appreciated
                      • theroadend
                        • Oct 2013
                        • 7
                        #2981
                        HI can any one help need to update firmware on skyboxf5s thanks
                        • epeppard
                          • Jun 2014
                          #2982
                          Hi, i'm looking for a channel list for skybox F6 that includes irish chanels, and as many other channels/ satillites as possible
                          • P&D
                            • May 2010
                            • 2684
                            #2983
                            AJ's Sky UK **Channel List Only Thread** for X5/F6 - Updated Regularly
                            • DeejayAJ
                              • Feb 2012
                              • 402
                              #2984
                              New update here.
                              • aaizoo
                                • Oct 2014
                                #2985
                                Hello AJ i have a skybox f5s about 1 week ago i downloaded that tp file for channels and succesfully got all my channels but now all channels gone, i followed the same procedure but nothing happened, I have followed this info of yours "
                                FAQ
                                How do I put this list on to my box?
                                Firstly, before any upgrade you should always backup! Once you've done that;
                                1. [*=1]Unzip AJ's List XX-XX-XX.zip with a program such as winrar & place the TP_PROG.DBS file onto the root of your USB drive.
                                  [*=1]In the Openbox menu delete your current channel list by going to the "Edit Channel" tab & selecting "Delete All".
                                  [*=1]Staying in the menu navigate to the "Tools" tab then "Upgrade by USB", change the upgrade mode from "Image File" to "Misc Files" then "Select & Upgrade" & select "TP_PROG.DBS" then press yellow, if all done correctly it should begin to upgrade.
                                  [*=1]Once the upgrade has completed restart your box & voil?!
                                How do I backup?
                                Make sure your USB is plugged in then navigate to Menu > Tools > Dump by USB > Change Dump Mode to "Misc File" > Click on "Select and Dump" > Select "TP_PROG.dbs" so it has a tick next to it then press yellow to "Dump onto USB", this will backup your channel list. To backup your "gift" just select the "CCcam.cfg" file instead of "TP_PROG.dbs". To backup your whole image "Dump to USB" before changing the dump mode. The required backup should now be on your usb stick, make sure to move it to your pc or be careful not to delete it.
                                but without success, i am a total newbie so be easy on me ; p am i missing something ? Because your thread says that it will work on skybox f5s.
                                Oh and i tried directly downloading from your webpage AJsat.co.uk but not worked help plz
                                or any one else plz
                                Many Thanks
