AJ's Sky UK Channel List **Discussion** Thread
  • staden321
    • Nov 2015
    • 73
    #3691
    Go to different channel 5 it's not in my favourites go to all channels then search by a to z you'll find it somewhere
    Sent from my SM-G850F using Tapatalk
    • bucharoo
      • Dec 2012
      • 20
      #3692
      Irish channels missing from tp_prog list update RTE1 TG4 TV3.
      • dpool
        • Aug 2013
        • 38
        #3693
        AJ will get around to it...
        also RTE 2 HD is gone for good (encoded differently now) , so replaced it with RTE 2...
        RTE Jnr changed also
        • DeejayAJ
          • Feb 2012
          • 402
          #3694
          Update for the Irish channels here, sorry for the delay - http://www.digital-kaos.co.uk/forums...=1#post2705364
          • noelf
            • Aug 2015
            having trouble loading the latest updates, keep getting file not found. Any ideas?
            • chrisl106
              • Nov 2014
              • 9
              #3696
              Hi, I installed the update for the Irish channels but I still cant get them, I did a scan too and still no joy, any ideas? thanks!
              • joe516
                • 1000
                #3697
                Irish channels r ok 4 me m8
                information given is to be used for educational purposes only
                Don't Forget To Say Thanks If You Like My Post
                IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
                If It Ain't Broke Don't Fix It
                • toe471
                  • 254
                  #3698
                  Not to sure if this has been corrected or not guys but the channel epg is not showing up? wats the process to find the other C5 and manual put it across yourself? I think its doing the blindscan thingy but not sure how?
                  • nay27uk
                    • Mar 2010
                    • 15
                    #3699
                    Hi I have noticed that for ages now channel 5 never has any info I.E when you turn the skybox F3 over it says what is on now and next on every channel bar channel 5.
                    Is this something to do with your channel list or is it a box fault? if the latter does anyone have a firmware update to fix it as skybox has none on the site and this is really annoying the hell out of me and my other half.
                    • WOODWARD395
                      • Apr 2010
                      • 628
                      #3700
                      Hi all just got two skybox's off a friend F5S thought I would set them up installing the channel list I get a mismatch so I am presuming they are clones
                      sorry my mistake just discovered you have to select misc files in upgrade source even if you only have one file on usb it will come up with file mismatch.
                      Education is not the learning of facts, But the training of the mind to think
                      So hit the thanks button if I have enlightened you.
                      • Hadron
                        • Nov 2012
                        • 2102
                        #3701
                        Originally posted by WOODWARD395
                        Hi all just got two skybox's off a friend F5S thought I would set them up installing the channel list I get a mismatch so I am presuming they are clones has anyone any idea where I can get a clone channel list from as searched everywhere I think all I can find are lists for original box's. thanks
                        Channel lists should work with original and cloned boxes. It's only the software (firmware) that has to be the correct type.
                        Are you sure that you are selecting TP_PROG.dbs when you are trying to install the list, & not "image file"?
                        • P&D
                          • May 2010
                          • 2684
                          #3702
                          Check you other post......http://www.digital-kaos.co.uk/forums...=1#post2710169
                          • WOODWARD395
                            • Apr 2010
                            • 628
                            #3703
                            I discovered what was wrong and notice a lot of people are doing the same getting file mismatch on other forums I found you have to select upgrade source and select the file individually and put the green tick at the side even if you only have one file on your usb if not you get the mismatch error.
                            • harveyboy73
                              • Jul 2013
                              • 8
                              #3704
                              HI IS THERE ANY PROBLEMS WITH THE SKY BOX OFFICE THXS
                              • staden321
                                • Nov 2015
                                • 73
                                #3705
                                Yea it shows WE or whatever it's called wrestling crap ha ha
