AJ's Sky UK Channel List **Discussion** Thread
  • aaa801
    • Aug 2012
    • 7
    #481
    Step One will be to remove the remaining BBC Red Button service will move from DSat7 to DSat1 (Astra 1N tp 45) but in order to make this fit and optimise how our more and less capacity-hungry channels are arranged, we need to shuffle some of our TV services around. So in the early hours of 12th October 2012:
    • BBC Three / CBBC (DSat1) and BBC News (DSat 2) will move to DSat6 (Astra 1N tp 48)
    • BBC ALBA and BBC One North East & Cumbria will both move from DSat6 to DSat2 (Astra 1N tp 47) BBC Four / CBeebies (DSat2)
    • BBC Red Button stream 1 (DSat7) will move to DSat1
    • cathaltoner
      • Jul 2012
      • 19
      #482
      I have a skybox s11, i have previously uploaded your channel lists, recently i noticed that Cbeebies is showing on Cbbc, i have uploaded ur most recent channel list and done a single sattalite blind scan. . . still same issue. . . any tips
      • aaa801
        • Aug 2012
        • 7
        #483
        read my post, list hasnt been updated to reflect the bbc transponder swap
        • deanlecky
          • Aug 2012
          • 48
          #484
          How can I make my own list?
          Firstly you'll need a channel editor, PVR800 editor is the simplest option, I've attached the .DBS version to the bottom of the post.
          Then you'll need a list to edit, either mine/someone else's which would be the best option or you could do a fresh scan yourself & edit the backup up file.
          Where do I run the PVR800editor? I would like to attempt my own list for multisat set up, but not entirely sure how?
          • andybhoy67
            • Jul 2012
            • 10
            #485
            Loving this list works a treat.
            BTW anyone having trouble with Disney HD? mine is showing as scrambled.
            • leehez1976
              • Oct 2012
              #486
              Originally posted by DeejayAJ
              Update : 17/10/12
              BBC News
              BBC One NE & C
              BBC Three
              BBC Four
              BBC Alba
              CBeebies
              CBBC
              Heart TV
              Capital TV
              Minor order change
              i am using winrar to extract should this be ok or should i use something different cheers lee
              when i have downloaded it then try to extract the file it says it is damaged , am i doing anything wrong ??
              • Tekken
                • Jul 2012
                • 38
                #487
                Download free version of WinRAR and extract the file using it
                • P&D
                  • May 2010
                  • 2684
                  #488
                  Originally posted by Tekken
                  If you have a backed up Image of your box just reload it and see if you get your channels back.
                  Many thx mate done that & there back
                  Thx Cookyp
                  • killaserj
                    • Oct 2012
                    #489
                    Cant get channel list working! Please help
                    Hi Everybody,
                    I have a problem! I have tried to add AJs channel list but it doesn't work. Here is what I am doing,
                    I have a skybox F3 which initially came with a list installed. I deleted the channels so that every time i exited the menu it said 'No channels found' and then I followed the steps above (downloaded Aj's list, extracted file, copied .dbs file onto usb and upgraded the box from the tools menu using the usb). Now once I exit from the menu and restart the box some channels work but there are no favourites in the favourites list (as should be with the list) and the channels are all in a messed up random order with a total of about 28 favourites there (without any names)!
                    Please can some one help me with this! I have tried to install different lists and the same thing happens with them all!
                    WOuld be very thankful to anyone who can guide me on what to do,
                    Thanks!!!!
                    Serj
                    • Tekken
                      • Jul 2012
                      • 38
                      #490
                      Originally posted by killaserj
                      Hi Everybody,
                      Thanks!!!!
                      Serj
                      You need to rename the Favs Title as how its Listed in AJs first post
                      • adammacleod
                        • Aug 2012
                        • 18
                        #491
                        Anyone having a problem with Sky One HD?
                        Scrambled for me. Every other channel works fine.
                        I scanned the transponder and tried the channel again but it is still scrambled. I have added Sky One(SD) and thats working fine so I can still watch what I want. Just found it a bit strange
                        • asiansensation
                          • 4
                          #492
                          I have an issue with National Geo Wild HD in the documentaries FAV group. Anyone else have this issue? I have scanned 3 times now and used this database to organise my favourites.
                          • taffy88
                            • Oct 2012
                            • 4
                            #493
                            sky sports 1/2 hd and 007hd
                            not working
                            • DeejayAJ
                              • Feb 2012
                              • 402
                              #494
                              The people with the HD channel issues, what region are you in?
                              What size dish & how old is it?
                              How much signal are you getting on working vs not working channels?
                              Check your LNB settings.
                              • Tekken
                                • Jul 2012
                                • 38
                                #495
                                These people probably running on some old MK LNB.. they just need to upgrade it to ZINWELL MK4 LNB (about ?6 on ebay) and problem solved!!
