AJ's Sky UK Channel List **Discussion** Thread
  • stonestaff
    • Nov 2011
    When I unzip this file it has no extension and its not recognised by the OpenBox
    Stone
  • smithie46
    • Aug 2009
    • 72
    with no $ on channel dont think it lets you ts or record a no it dont on s9 tried it months ago
    • f1nuts
      • Mar 2012
      • 19
      when i update why am i only seeing 8 fav not 25?
      • Wingnut
        • 376
        maybe u need to do a factory default first?, but remember it might wipe important things,make sure u save them first etc
        • tjnwil4
          • 21
          thanks great channel list just need a better epg and were cooking with gas
          • DeejayAJ
            • Feb 2012
            • 402
            Yeah you're right, just tested it on my S12.. odd, thanks.
            Updated OP.
            • DW190
              Probably because the software on you box is only capable of eight. Updating the software may cure it.
              • brithepi2k
                • Feb 2011
                • 23
                put these onto my Openbox S10 and now the box is dead? Nothing displays can anyone help?
                Cheers
                • DeejayAJ
                  • Feb 2012
                  • 402
                  Cheers
                  All 4 of these files has been tested on my S12 & work fine. Did you edit the files? Could you have rebooted before the flash had ended? Which list was it?
                  • Manic01
                    • 5117
                    A ch list cannot kill a stb, simple as that.
                    • brithepi2k
                      • Feb 2011
                      • 23
                      Its ok for some reason a faulty usb was able to transfer the files to my box but when i upgraded by usb and that had complete i turned my box off and on and it was dead waited a good 5 minutes to see if it turned on but nothing was displaying then had to put the firmware back on the box...
                      • Rahxie
                        • Mar 2012
                        • 12
                        Cheers
                        Restart your s10 and the channels will reappear. The same happened to me so I tried a restart and it works a charm.
                        • irfansaeed
                          • Mar 2012
                          Thanks for the List? Any idea how Can I edit this and revise according to my requirement.
                          • DeejayAJ
                            • Feb 2012
                            • 402
                            S9-Editor_HD.zip
                            • brithepi2k
                              • Feb 2011
                              • 23
                              Sound is out of sync for me when someone talks...
