AJ's Sky UK Channel List **Discussion** Thread
  • Yosser2000
    • Mar 2012
    #46
    Originally posted by DeejayAJ
    There's only 1 isn't there? It's the last channel in the entertainment section.
    Updating to 2-2-12 firmware solved the audio commentary issues for me (thanks short360uk).
    I've merged my channel list with this firmware if anyone has the same problem, means you don't have to type in the favourites either Remember to backup your current firmware & Cccam.cfg just incase & revert to factory settings before upgrading. (Clone safe).
    Is this for the the s9 or s10?
    • DeejayAJ
      • Feb 2012
      • 402
      #47
      I think it's this firmware; http://www.digital-kaos.co.uk/forums...ymousx-253796/
      It says both if you factory reset before upgrade, only tested on my S12.
      • PadZ
        • Jan 2012
        • 19
        #48
        Can somebody tell me how many channels are in the box office favourite before I download after a list with none hd sbo channels
        • DeejayAJ
          • Feb 2012
          • 402
          #49
          There's around 40 on my list, not got the capability to test them myself though.
          • PadZ
            • Jan 2012
            • 19
            #50
            40!! Do you have the non hd sbo on your list mate I didn't know there was 40 available
            • DeejayAJ
              • Feb 2012
              • 402
              #51
              I think they're all there somewhere, maybe some duplicates & inactive, I can't test them.
              • PadZ
                • Jan 2012
                • 19
                #52
                Cheers djay your list is great way better than the 1 I had, only got to watch for 5 mins then the server went down from my cs provider
                • PadZ
                  • Jan 2012
                  • 19
                  #53
                  Since updating I'm experiencing a lot of freezing is this down to upgrading my firmware or my provider
                  • purdybread
                    • Dec 2010
                    • 9
                    #54
                    After updating I also experienced freezing on the encrypted channels. could view for anything between a couple of minutes to half an hour.
                    I believe the problem lay with the new firmware mentioned in the thread.
                    Tried everything I could think of. I ended up reflashing using the attached firmware. my box is a s10, this firmware works for both s10 s9. I got it from another thread on the forum here. After installing the firmware I could install the channel list, but had to rename the favorites manually. everything working well for last 2 days.
                    • souldude
                      • Jun 2011
                      • 37
                      #55
                      Since using AnonymouSX firmware i have had no endless trouble with it feezing and glitching on 4 boxes (S10), spent loads of time trying to find out why, even thought the boxes were faulty.
                      but i found that the nov firmware worked so much better without a glitch and freeze and also to point out that if you have more than 1 box on a sky lnb people say it causes the boxes not to switch to Vertical (the voltage error ). but since this Nov firmware i have got 3 boxes (S10) on same lnb working on all HD channels and not had a problem since.
                      I put the firmware up later if req.
                      • iain66
                        • Dec 2010
                        • 52
                        #56
                        How can I rename the favs as they are wrong kids is sport and vice versa and some just say fav 15
                        • r0nnie
                          • Feb 2012
                          • 27
                          #57
                          Originally posted by r0nnie
                          i was wondering the sports interactive favs (sly sports red button match choice), is it possible to get these channels in hd or are these ones sd only
                          any info on these then?
                          • DeejayAJ
                            • Feb 2012
                            • 402
                            #58
                            Did you reset to factory default before upgrading? My Skybox S12 is working perfectly with the firmware :/
                            • DeejayAJ
                              • Feb 2012
                              • 402
                              #59
                              Yeah $ky Sports interactive isn't in HD.
                              • souldude
                                • Jun 2011
                                • 37
                                #60
                                No these are SD channels only on interactive
