nothing to worry about, just find a firmware your happy with and stick with it, most updates arnt worth bothering with,so dont bother unless you have problem.the channel lists like ajs are udated to keep your lists up to date, there worth keeping an eye on every now and again as the channels move about every so often, in short if its working just leave it alone , had mine for about a year and to be honest most of the problems i have had are through meddling about with it when it was new, boys and there toys ha ha, now the novelty has worn off it does what i want out of it ,and as long as it stays that way it gets left to get on with it without much input from me .
AJ's Sky UK Channel List **Discussion** Thread
Music Tv's
tp. 12,524 GHz, pol. V, SR: 27500
ID: 55113 (Clubland TV)
PID V: 2557 (MPEG-2/SD)
PID A: 2558 (eng)
PID PCR: 2556
SID: 55113
PID PMT: 282
Provider: Sky Digital
ID: 55114 (Massive R&B)
PID V: 2560 (MPEG-2/SD)
PID A: 2561 (eng)
PID PCR: 2559
SID: 55114
PID PMT: 283
Enjoy !Last edited by Frostee; 17 July, 2012, 11:10.Comment
Hmm I don't think a channel list can do that directly, there might have been a problem during flashing.. have you got an rs232 cable?
There's no radio channels on my list.. yet.
There's a short tutorial in the second post.Comment
I must be thick
when i extract the file and stick it on the root of the usb
it not .dbs file
its just TP.PROGS (file)
tried that on box no file found
renamed file to TP.PROGS.DBS = file mismatch
renamed file to TP.PROGS.dbs = file mismatch
what am i doing wrong? its fat32 formatted
for a openbox s10Comment
you have to extract the zip file,then you see tp.prog.dbs.I must be thick
it not .dbs file
for a openbox s10
then drop that onto formatted memory stick,stick it in and updateComment
