AJ's Sky UK Channel List **Discussion** Thread
  • mack441
    • Sep 2009
    • 32
    #241
    starplus hd working ok m8
    • khartoum
      • Aug 2012
      #242
      thanks for the chanell list any chance for amotorizes list
      • TheTruth
        • Jul 2012
        #243
        Anyone know how I can rearrange the bouqets? I would like to move HD channels to the top of the list.
        I'm using a Skybox M3.
        Thanks in advance
        • mickydibble
          • 2166
          #244
          Originally posted by mack441
          skybox f3 firmware with bouquets channels allready in thanks to aj for channel list
          https://rapidshare.com/files/1262047...1HD_Backup.abs
          is this with or without adult? cheers micky
          • terryuk22
            • Mar 2009
            • 33
            #245
            how do you make this list as i would like
            1.culture
            2.movies
            3.sports
            and all the HD chans in each on at the top
            • popeye2008
              • Aug 2012
              hi, can anyone show me how to backup my channel list before i load the new updated one?
              thanks.
              • madmatt30
                • Jul 2012
                #247
                thanks.
                put a usb stick in back of box
                open menu
                tools
                dump by usb
                press right to change dump mode to 'misc files'
                press 'select & dump'
                press ok button on option 1 - TP_PROG.dbs
                tick should appear next to it
                press yellow button to dump
                job done ;-)
                • Markanddeb
                  • Jul 2012
                  • 30
                  #248
                  AJ any chance you can try and sort a list out for multi sat for the football this season
                  I wouldnt ask if you weren't so damn good at it
                  • gnashers
                    • Apr 2009
                    • 30
                    #249
                    that would be class ,,AJ you the man , thanks for the list
                    • DeejayAJ
                      • Feb 2012
                      • 402
                      #250
                      If you give me a list of channels I can add them but it'd be as easy for you to just scan the single transponders of the particular channels you're after, info at KingofSat - 13E / 19.2E
                      • Tekken
                        • Jul 2012
                        • 38
                        #251
                        Channel AAJ TAK new frequency from 07-Aug-2012
                        11490 V 27500
                        • DeejayAJ
                          • Feb 2012
                          • 402
                          #252
                          Would anyone care if I removed the SD channels that are available in HD from the list?
                          • mikeofmancunia
                            • Aug 2012
                            New to all of this so thanks for the list! Assume it contains Irish Channels?
                            EDIT - actually read the 2nd page and your post confirms it does. Excellent work!
                            • gtirron
                              • Apr 2012
                              will this work on skybox s12
                              • redralph
                                • 171
                                #255
                                Ive no problems with the SD channels being removed. Most people seem to be geared up to HD now
