AJ's Sky UK Channel List **Discussion** Thread
if anyone is looking for an updated version here is one compiled by adammacleod and slightly altered by myself
credits go to adammacleod
all are in sky-order 101 etcAttached FilesComment
Quick Question...
Hi, I have a skybox F3 with a preloaded gift, can't find some channels and would like to update the channel list. But I'm worried I might wipe the gift as the seller didn?t give me any password. I?m relatively new and therefore would like to know if this process simply updates the channel list only and thus keeping my current subscription intact?
Also, can I apply it to a Sky Box F3 without any difficulty?
Thanks in advance if anyone could help me, appreciate it.
Kind RegardsComment
Hi,Hi, I have a skybox F3 with a preloaded gift, can't find some channels and would like to update the channel list. But I'm worried I might wipe the gift as the seller didn?t give me any password. I?m relatively new and therefore would like to know if this process simply updates the channel list only and thus keeping my current subscription intact?
Kind Regards
I use an S12 box, and had the same concern as yourself. I took the plunge and updated the channel list, and have done several times since. All this without disrupting the pre-loaded settings. settings.
Like yourself I'm a noob at all this, I can only comment on my own experience on S12. Not sure if the same would apply to F3.Comment
Thanks for your input, i suppose it should be the same. My brothers into cricket and if i also take the plunge and it goes pear shaped, could mean no sports and a whole new problem all together... (BIG brother)
Ill wait to see if anyone with a F3 can confirm...
Thanks mate.Comment
I know what you mean. I asked a similar question over the weekend. See response on page 28 post #416 from a more experienced FM. Good luck.Thanks for your input, i suppose it should be the same. My brothers into cricket and if i also take the plunge and it goes pear shaped, could mean no sports and a whole new problem all together... (BIG brother)
Thanks mate.Comment
Thanks, seems like i can at best only mess up the channel list. how exactly did you backup the channel list?
Also, did you ever resolve your Audio Stream issue?Comment
I never got a response on that query, but I did the following which I think created a back-up.
With a USB stick installed:
Menu > Tools > Dump by USB > Change Dump Mode to "Misc File" > click on "Select and Dump" > select "TP_PROG.dbs" so it has a tick next to it > Then press yellow to Dump onto USB.
A File called TP_PROG.dbs will now be on your USB stick. I assume this is an image of your current channel set-up, so save this somewhere safe.
Once I updated the channel list (The Fav categories have to be named manually).
I did have a sound issue. So I did a channel scan afterwards and no longer seem to have the Audio Description issue. Not sure if this is resolved, but I will monitor the issue.Comment
Thanks guys, managed to back it up and also update my channel list...Last edited by mostw4nt3d; 1 October, 2012, 21:28.Comment
i cant seem to find the SD sly sprts channels... anyway to include them?Last edited by mostw4nt3d; 1 October, 2012, 21:55.Comment
