AJ's Sky UK Channel List **Discussion** Thread
  • digicon
    • 8261
    #1426
    Originally posted by bambam72
    is this list upto date? and does it go on f5 skybox? ive just got f5 skybox and aint clued up about it, but would like the channels sorting into order? any help is appreciated
    Works on the F3 & F5 as well as others, It may not be regionalised for your area ie: BBC1,ITV etc... but that is easily rectified by doing it yourself via the remote
    • Merkel
      • Apr 2012
      • 5
      #1427
      Thanks for this! my DM800SE just died and decided to get a Skybox F3.
      • rborhara
        • Dec 2012
        • 32
        #1428
        Thanks AJ for your list - However now with someone else posting a 100% up to date SKY UK Channel list with SKY numbers on a different thread on a daily basis , Ive gone over to their list
        Thanks again
        • dansage
          • 68
          #1429
          just saying "unexpected end of archieve"? and wont let me save to mem stick?
          • 600fazer
            • May 2013
            worked fine on my s10 thank you
            • digicon
              • 8261
              #1431
              Thanks again
              I cannot believe i just read this, Talk about rubbing salt in the wounds i just hope AJ does not take offence and decide to knock these lists on the head when he sees comments like this, then what will you do especially if the other List maker decides to call it a day as well. Sometimes its better to keep Stum and not post at all.
              AJ i am sure your level headed enough to know that 99.9% of the Open/Skybox users appreciate your hard work in churning out these Lists. Keep up the goodwork
              • dansage
                • 68
                #1432
                im still struggling to open the rar file? just keeps saying unexpected end of archive? any ideas? it works fine for other rar files
                • rickyw88
                  • 21
                  #1433
                  Hi mate, just go to AJ'S site here and download the non rar'd file easy as pie! AJsat.co.uk: AJ's Openbox List 29-6-13
                  • dansage
                    • 68
                    #1434
                    sorted! thanks very much
                    • geoffe30
                      • Mar 2013
                      • 8
                      #1435
                      Thanks again
                      Im pretty new to this forum and learning so much off it. i cannot believe i just read this quote, how disrespectful!
                      AJ keep up the good work, your time and hardwork is much appreciated by the majority of us...
                      • durasoft
                        • Aug 2008
                        • 57
                        #1436
                        AJ does a fantastic job with his Channel List.
                        Their will be people who prefer other version's.
                        But i bet some guy's start off with AJ's then they modify it and some might take the credit.
                        I slighty modify mine, but i take no credit for the hard work AJ's put into it.
                        Big Supporter of AJ's List..................
                        Humax FoxSat-HDR
                        Great HD/SD Box with 500GB HardDrive
                        Manhatton HH-120 42E-30W
                        Triax 88cm 0.3db
                        SKYBOX F3
                        HD-Fix F/W from www.skybox.cc - CCcam/MGcam/Newcamd
                        Intel Core i7 [email protected]
                        MSI R7970 Twin Frozr Boost Edition
                        • sickswan
                          • May 2013
                          • 43
                          #1437
                          can you point me in the direction of how to edit the list eg. regional programmes please and is it a ball ache to do? cheers
                          • DW190
                            • May 2012
                            • 1263
                            #1438
                            Its quite easy when you know how. Just go into Menu, Edit Channel, Favorite edit, Press Fav and select the Fav you want to add to, select channels to add by pressing ok then right arrow and the +. Exit and Save.
                            If you balls it up, just upload the list again and try again.
                            Remember Practice makes perfect.
                            I'll bet AJ can do it with his eys closed.
                            • yarg2k7
                              • May 2013
                              • 6
                              #1439
                              Check the first page of the thread. Easy to do but still a pain to do it yourself
                              Sent from my GT-I9100 using Tapatalk 2
                              • sickswan
                                • May 2013
                                • 43
                                #1440
                                cheers, Is it possible to swap Itv Granada for normal Itv for example, i know this is low level stuff and has probably been said a thousand times but i cant seem to do it! Just downloaded that edit programme, ill have a go with that!
