I have seemed to lose my espn.
AJ's Sky UK Channel List **Discussion** Thread
just worked for me pal, if you look up a few posts on this page i have re posted aj's channel listThanks IanComment
fair play but no good that download from emmaian mtv hd missing was fine with ajs 25/7/13.more messinLast edited by makster1978; 30 July, 2013, 22:19.Comment
If it was working on aj's 25/7/13 then should be working as i downloaded that one then just added espn, I think more people should learn how to do it there self as people like you who moan when someone tries to help others do this off there own back and without people like AJ and others what would you do then to keep your box up to date with channels.
Rant over...........Thanks IanComment
FAQ
How do I put this list on to my box?
Firstly, before any upgrade you should always backup! Once you've done that;
- Unzip AJ's List XX-XX-XX.zip with a program such as winrar & place the TP_PROG.DBS file onto the root of your USB drive.
- In the Openbox menu delete your current channel list by going to the "Edit Channel" tab & selecting "Delete All".
- Staying in the menu navigate to the "Tools" tab then "Upgrade by USB", change the upgrade mode from "Image File" to "Misc Files" then "Select & Upgrade" & select "TP_PROG.DBS" then press yellow, if all done correctly it should begin to upgrade.
- Once the upgrade has completed restart your box & voil?!
How do I backup?
Make sure your USB is plugged in then navigate to Menu > Tools > Dump by USB > Change Dump Mode to "Misc File" > Click on "Select and Dump" > Select "TP_PROG.dbs" so it has a tick next to it then press yellow to "Dump onto USB", this will backup your channel list. To backup your Server/Gift whatever you want to call it just select the "CCcam.cfg" file instead of "TP_PROG.dbs". To backup your whole image "Dump to USB" before changing the dump mode. The required backup should now be on your usb stick, make sure to move it to your pc or be careful not to delete it.
there you go pal
give all the thanks to ajComment
any one had this where you update and all the H work but none of the V work ? I have this problem at the min any help pleaseComment
Hi, i just did the update, but now under kids, the movies channels appear, ect. Any quick fix to this?Comment
HI AJ, amazing job with the sky channels would be los without you as freq's keep getting changed! One request is can you check out the 4Music channel, its coming up named as the 4Music channel but when you go to it, its the Heat Channel thats showing on it, checked all the rest of the music channels and none of them are 4Music under another name. Anychance you can see if you are able to get the 4Music channel corrected as it has some great telly shows on it like 8outof10cat repeats! Cheers springerComment
