AJ's Sky UK Channel List **Discussion** Thread
  • ndoc3
    • Aug 2013
    • 6
    #1651
    does it matter if i'm using an external hard drive to put on the upgrade, it won't seem to connect to the box whereas my USB stick does connect?
    • patslfc
      • Mar 2012
      • 7
      #1652
      anyone else racing uk working ?
      • welshred
        • Jun 2013
        • 23
        #1653
        Yeah, mine seems to work fine ATM
        • gunner12
          • Aug 2013
          Just updated to latest channel list - seems like various channels eg BT Sport 1, are freezing very often. What could be the causes of this? Any resolutions?
          • Daz111
            • Aug 2013
            #1655
            Hi guys can you help: I have updated my box with AJ's UK Channel List a couple days ago after losing espn hd, sky sports news hd etc. The list worked great I got my channels back but today I dont have espn hd or and of the BT sports hd channels. Im guessing they have changed today or last night. Is there a new list or does anyone know the transponder to get them back?
            • rarfie
              • Jul 2013
              • 4
              #1656
              hi can someone help me because my list says stuff like fav group 17 and stuff, and I would like it to be like aj's list, cheers rarfie
              • patslfc
                • Mar 2012
                • 7
                #1657
                can anyone give me there racing uk freqency ? y isnt mine working ??
                • cgscott
                  • 3513
                  #1658
                  freq: 11527 27500
                  Patience is a virtue.
                  • bryan654
                    • Oct 2012
                    • 20
                    #1659
                    Anyone else not got BT Sport?
                    EDIT: just read provider might not be sporting it yet.
                    • garyfrew79
                      • Jan 2013
                      • 5
                      #1660
                      does the latest list enable me to get bt sport and espn
                      • shenmue
                        • 10
                        #1661
                        All channels are working except BT Sports and ESPN, must be a provider issue i guess. I'll have to watch the UFC tonight on a stream. No big deal.
                        • MonsterSquad
                          • Jun 2013
                          • 38
                          #1662
                          Watched the game today and the same thing happened. ...had to turn off the box then turn back on again. Kind of frustrating.
                          Sent from my GT-I9305 using Tapatalk 4 Beta
                          • donpel
                            • Aug 2013
                            #1663
                            scrambled channels
                            Originally posted by DeejayAJ
                            Update : 31/7/13
                            ESPN HD
                            Update : 25/7/13
                            Sky Sports News HD
                            Eurosport 2 HD
                            Discovery HD
                            More4 HD
                            Word Network
                            Madani Channel
                            Kix Power
                            Update : 22/7/13
                            Sky Arts 2 HD
                            High Street Xtra
                            Drama
                            BEN
                            FAQ
                            How do I put this list on to my box?
                            Firstly, before any upgrade you should always backup! Once you've done that;
                            1. [*=1]Unzip AJ's List XX-XX-XX.zip with a program such as winrar & place the TP_PROG.DBS file onto the root of your USB drive.
                              [*=1]In the Openbox menu delete your current channel list by going to the "Edit Channel" tab & selecting "Delete All".
                              [*=1]Staying in the menu navigate to the "Tools" tab then "Upgrade by USB", change the upgrade mode from "Image File" to "Misc Files" then "Select & Upgrade" & select "TP_PROG.DBS" then press yellow, if all done correctly it should begin to upgrade.
                              [*=1]Once the upgrade has completed restart your box & voil?!
                            How do I backup?
                            Make sure your USB is plugged in then navigate to Menu > Tools > Dump by USB > Change Dump Mode to "Misc File" > Click on "Select and Dump" > Select "TP_PROG.dbs" so it has a tick next to it then press yellow to "Dump onto USB", this will backup your channel list. To backup your Server/Gift whatever you want to call it just select the "CCcam.cfg" file instead of "TP_PROG.dbs". To backup your whole image "Dump to USB" before changing the dump mode. The required backup should now be on your usb stick, make sure to move it to your pc or be careful not to delete it.
                            Will updating my channel list effect my server settings etc?
                            No, your channel list is the only thing that's affected but it's always wise to backup just in case as problems can happen. This is for channel lists only, firmware updates erase everything.
                            Why aren't the channels in the same order as my Sky box?
                            I put the channels in the order that I feel is the most efficient & simplest to use. There are plenty of Sky ordered lists if that's what you prefer, Sattv5's list is the best I've seen (LINK).
                            Why are my favourites not named correctly?
                            Favourites only retain their name if you upgrade a whole image, for channel list upgrades you'll need to manually change them in the Openbox menu with your remote.
                            How do I edit the order of the favourites?
                            The only simple way would be to use SetEditHD100 (LINK), the program isn't free but It'll let you make 25 changes before it stops working.
                            The file is corrupted, not found or won't download.
                            Have you unzipped it? If that's not the issue try downloading with a different browser/device, make sure your zip program is working correctly or use a different USB stick.
                            Does this list have 'X' channel?
                            The list should have every channel including all Radio, Box Office & Red Button services.
                            How can I make my own list?
                            Firstly you'll need a channel editor, PVR800 editor is the simplest option, I've attached the .DBS version to the bottom of the post. Then you'll need a list to edit, either mine/someone else's which would be the best option or you could do a fresh scan yourself & edit the backup up file. The satellite info you need to edit lists is at KingOfSat. It looks complicated but it's pretty self explanatory, check out other specific threads on the subject or ask questions in this one if you have any issues.
                            Which boxes is this list compatible with?
                            Skybox/Openbox S9, S10, S11, S12, F3, M3, X3, F5 + more.
                            I followed all the steps you explained and got all the channels but most of them are scrambled
                            • Tekken
                              • Jul 2012
                              • 38
                              #1664
                              Dude this channel list is not put up here so you can watch the channels for free!!! This list is only here to keep channels Tidy and in Fav Groups
                              • dpool
                                • Aug 2013
                                • 38
                                #1665
                                Im using a skybox f5 and it will only read Fat32 formatted memory, maybe your harddrive is formatted in NTFS and that is the reason it will not read it....
