Been using your list for quite a while now & noticed some things which have not been corrected. Please don't see this as any type of criticism, they are just observations that you may not be aware of & might want to consider in your next update. I did, in fact, correct a lot of these in earlier versions, but was never quick enough to upload them before the next update came along.
The channel numbers are when viewed as "All channels".
1) The FTA Favs list should not include: 5 - Channel 5 HD, 60 - Sony Movies, 61 - Sony Movies +1, or 232 - Climax.
2) The following channels should be marked as $: 61 - Sony Ent, 62 - Sony Ent +1, 69 - E!, 74 - PBS UK, 113 - Style Network, 360 - Geo UK, 462 - Channel 4 Ire, 464 - Channel 4 +1 Ire, 470 - E4, 471 - E4 +1.
3) 74 - PBS UK should be PBS America.
4) 361 - Geo News should not be $.
5) 9 - $ly Living +1 (11508H) is the Irish version. There is another version on 12285V which, I assume, is the UK version.
6) The following should be in the FTA list (some of them are not in the "All channels" list at all): ITV2,3,4, Channel 5, E4, More4, 4Seven, Challenge, Viva, The Box, Kiss, Smash Hits, Heat, Kerrang!.
I'll try to fix those in the next update. I don't have an openbox to test these lists anymore so a lot of these issues will go unnoticed until someone mentions them so thanks!
Just adding this update all credit goes to Aj as it is his file, people have messaged me for the ID channel so it is added in this update of AJ's 17/08/13 it also is the adult one.
Many thanks got AJ and the others who are updating these channels on a regular basic!!!
I would be very grateful if perhaps we could also put the SD vertions of Sly Sp~~ts E""PN, Bt's etc as I think this would stop all the moaning going on about certain channels either not working or having glitching problems?
For example.....I was watching a sly sp**ts footie match on the weekend and mine had a few problems every 2 - 3 mins but I found a interactive SD channel and not a freeze in sight?
I just think its a good idea putting those other SD channels in as well because if sly decide to change frequences at least we have the SD channels to go and we not have to rely on AJ to update all the time!!
I'll add the SD sports channels as well.
Thanks for that.
Another thing I meant to mention is that certain options are greyed out in the "Installation" menu (antenna setup, TP list, single sat search), since installing your last 2 or 3 updates. The Sky UK line in the Sat list isn't automatically selected. OK has to be pressed to place a tick next to the details.
Ok so i have tried this channel list did every thing as mentioned by AJ in the guide. Backed up the old one uploaded the new but it seems a bit strange that i have got bbc and aljazeera channels in SPORTS channels and no skysports, espn or setanta bt sports etc? After SHOPPING tab it shows fav12 fav13 fav14 etc instead of proper names. Inmy old channel list i have sky sports 1234 and bt sports espn etc bt is completely diff to this one and loads of channels are missing as well.
May be i am not doing it right ? Can any one help ?
UPDATE
I have just checked MOVIES channels and got all sports channels on that list in Favorites. most channels are still missing not sure why
still confused :\
Hi aasi54,
Did you delete the old list before updating to AJ's list? then power off and back on?
hello Welshred,
thanks for answering and yes i did that i backed it up 1st then transferred it into laptop, deleted every thing from usb, moved the new list into it and then updated the channel list through the USB. Pressed Exit twice and then restarted the BOX. For some reason channels are not under the right TABS like i have got all sports channels under MOVIES list and nothing in HD AND IN sports List i have news channels.
Hi, like aadi54 I am also having the same issues with the tabs not being under the correct headings. Sports are under Movies etc. Wondering if I have done something wrong. All the channels work perfectly fine and thank you AJ for the great list.
Was your previous channel list also an AJ one, or was it by someone else?
I am wondering whether the channel favourites headings get confused when you update a different providers channel list?
