See post #2082 on this thread AJ Temporary Update for Setanta
AJ's Sky UK Channel List **Discussion** Thread
October 15th is latest working channel list if that helps Riz, put that one on and all channels should work fine Andy.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
Can someone explain why Setanta Sports 1 isnt working for me? Every other channel works and I've read the FAQ tried evreything but this channel wont work for me for some reason? Just want to watch the footie! Any help is much appreciated. Thank you AJ for the continuous good work.Comment
It may not be AJs list depending on signal level you receive for this channel.Can someone explain why Setanta Sports 1 isnt working for me? Every other channel works and I've read the FAQ tried evreything but this channel wont work for me for some reason? Just want to watch the footie! Any help is much appreciated. Thank you AJ for the continuous good work.
What is the signal level/quality (press info button twice on channel)?Last edited by bbb_uk; 19 October, 2013, 18:31. Reason: removed bit about incorrect thread as admin moved postComment
The latest AJ list (15/oct) has BTSports 1&2 HD working just fine.
The transponder for BT Sports 1 HD is 12574/H/23000 (press info button twice to get this info).
If you're using AJs latest list and transponder for BT Sports 1 HD is as above then it's nothing to do with AJs list in which case its likely it's your provider (which were not allowed to talk about).Comment
