AJ's Sky UK Channel List **Discussion** Thread
Hi, will this work on my F6 box. I am a newbie and wouldn't want to mess anything up. When I press the menu key it brings up the installation and setup screen. Where would I find the Factory settings please?My Favourites are all wrong since I loaded your list how do i fix them ?
The way to get The favourites under the correct headings is to load the default Database:
On the remote select Menu > Factory Settings > Select Yes > Then Press Blue (Don't make any choices at the menu)
The screen will flash black and you will be back at the menu. If you check your favourites now they should all be in the correct orderComment
Tried loading AJ's channel list on a skybox f3s,(done this 100's of times ,no problem's), box gets stuck on load.I say ok and put it down to bad luck so I try it on a new f3s and bingo same result,stuck on load.My computer recently crashed and I got it fixed (new hard drive) could this be the root of my problems?Comment
I have just loaded the latest channel list and i'm getting an awful lot of "invalid program search" . I've double checked it is the right one. There's no way this could be causing the problem is there? It wouldn't affect any other settings would it? sorry if these questions are stupid.Comment
I had missing channels but when i used an older channel upadate. (4/4/14) they came back think its the latest update thats had problems.Comment
There's another red sticky that contains AJ's channel lists **only**.Comment
