No channel list will give you Sky's HD movie channels:-
AJ's Sky UK Channel List **Discussion** Thread
go into main menu > factory settings press on yes then hit blue button on remote your screen will flash once then go back to tv screen all favourtes will be back in order,that is if you have used ajs channel listComment
information given is to be used for educational purposes only
Don't Forget To Say Thanks If You Like My Post
IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
If It Ain't Broke Don't Fix ItComment
Hi all
Ive had my openbox for 18 months and have updated my channel list previously ok, but getting a mental block. I downloaded the latest TP_Prog.zip and upgrade .rar file to usb. I unzipped the TP Prog file and then upgraded by usb on the openbox. I got a new set of channels but a lot do not display, either blank or no signal appears. Have i upgraded the channels correct or not???Comment
Can you give some examples of channels that do not display?Hi all
I don't know if you realise, but all of Sky's HD movie channels, plus some other HD channels are no longer viewable.
Have a look here:-
No. To update the channel list it just has to be one file - the unzipped/extracted TP_Prog.dbs file only on your usb drive. You also need to delete the old channel list first (this is what I do on a F5 box I am assuming openbox menus are the same as these boxes use same channel lists).Comment
Also Sky 3D is no longer on 12460H. It's now on 12324V.
BBC3 HD (and CBBC HD) is showing a test card (will probably be used for Commonwealth games) on 11464H. The real BBC3 HD is on 10847V.
ITV4 +1 is showing ITV Encore +1 on 10906V. ITV4 +1 is on 10832H.
Showcase +1 is showing invalid. The info is pointing to the same as that for Info TV +1. Showcase +1 isn't listed on KOS. Is it still broadcasting?
Nickelodeon +1 is showing Nickelodeon.
Nick jnr peppa is now Nick jnr 2.Last edited by Hadron; 7 June, 2014, 21:24.Comment
