AJ's Sky UK Channel List **Discussion** Thread
  • cooper1980
    • Jul 2013
    • 11
    #2881
    I tried updating my channel list this morning but nothing happened they are still the same '$$$'. So I tried what was said in earlier post about updating firmware but when I did this it said 'Hardware Mismatch'. Any ideas. Thanks.
    • cooper1980
      • Jul 2013
      • 11
      #2882
      Managed to find firmware that worked it all ok now
      • cooper1980
        • Jul 2013
        • 11
        #2883
        Originally posted by Conor mc
        It does say that and that indeed is the size of the file,so I've obviously download it correctly.
        But when i update via the box,it mustnt work. When i hit upgrade by usb its saying upgrade none. Any ideas??
        Hi Try this;-
        Press Menu on remote, and highlight ''Tools''
        Select 'Upgrade by USB'
        On new window, use arrow keys to change top line to 'Misc Files'
        Move down to 'Select and Upgrade'
        A new window opens, select 'TP_PROG.dbs' press green button (or Ok) to place a tick by it then press yellow button to upgrade
        remember to put a tick by it so its selected. hope this helps.
        • DeejayAJ
          • Feb 2012
          • 402
          #2884
          New update, here
          Let me know if you find any issues. I'll try to update the X5 list later.
          • V1lla
            • Jul 2013
            • 14
            #2885
            BBC Three HD is ok until this update is added then it knocks it out...
            • Hadron
              • Nov 2012
              • 2102
              #2886
              I notice that Box Office 42 is showing Forces TV.
              • DeejayAJ
                • Feb 2012
                • 402
                #2887
                I'll check that in the next update but BBC3 HD is working fine here, anyone else?
                • termiantor
                  • 400
                  #2888
                  working fine here and also have epg now thanx again
                  HAD THE PARTY LOL
                  • bigade1
                    • Oct 2013
                    • 340
                    #2889
                    Just checked today at 19.43 and the BBC3HD channel is showing a screen accompanied by music which states RED BUTTON HD and with the BBC Sport logo underneath it while when checking the sd version it is showing live athletics. Using the full ( Adult included ) latest list on a F5S.
                    • octron2008
                      • 6
                      #2890
                      Hi does anyone know if there's a list that has Astra 28 and 19.2? so far all the lists are for 28 (S*Y), or direct me where to get it.
                      • digicon
                        • 8261
                        #2891
                        you may struggle to find a pre-made list for your requirements as these type of receivers are basically Plug & Play and the majority of users buy them for predominantly 28.2? east and so the channel lists available only cover this satellite.
                        The best solution would be to load the 28.2? east satellite and then add 19.2? east yourself and create your own personal channel list
                        • android guy
                          • Jul 2014
                          #2892
                          I appear to have lost all channels except the freeview channels. I have updated the channel list with the latest 15-7-14 but the channels remain srcambled.
                          Any ideas?
                          Ta
                          • martin035
                            • Apr 2014
                            • 1308
                            #2893
                            Any ideas?
                            Ta
                            Could be an internet problem, check to see if your box is connect ie see if YouTube works
                            If internet OK then you need to contact your provider
                            • ar5ena1
                              #2894
                              Is anyone else having problems with Sony Max and ESPN (both SD)? All other channels seem to be working fine as far as I can tell
                              • android guy
                                • Jul 2014
                                #2895
                                Thanks for the reply.
                                I can access YouTube but when I try to download as it where it says downloading pls wait & stays at 0% but the weather app updates fin and you**** works a treat.
                                I tried turning DCHP on & off but still the channels are scrambled.
                                Any Ideas?
                                Ta
