AJ's Sky UK Channel List **Discussion** Thread
  • CrAcKeDuPII
    • Oct 2013
    • 19
    #3001
    Hi AJ, thanks for all your great work. Do you have a list for the Skybox A6 please. Not sure if the X5 one works, but that hasn't been updated since August.
    Thanks,
    CrAcKeDuP
    • joe516
      • 1000
      #3002
      Thanks,
      CrAcKeDuP
      no updated yet m8
      information given is to be used for educational purposes only
      Don't Forget To Say Thanks If You Like My Post
      IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
      If It Ain't Broke Don't Fix It
      • CrAcKeDuPII
        • Oct 2013
        • 19
        #3003
        Thanks Joe516. Just tried X5 list on A6 - doesn't work properly.
        • DeejayAJ
          • Feb 2012
          • 402
          #3004
          New update - http://www.digital-kaos.co.uk/forums...ml#post2414508
          I'll try to update the other lists soon. The X5 lists works on the F6, not the A6 as far as I'm aware. I'll have a look later to see how easy it'd be to make an A6 list.
          • worcestersauce
            • 136
            #3005
            I've been transferring photos from one laptop to another for my good wife via memory stick and have since wiped clean the memory stick. This is the memory stick I use to update AJ's list onto my F3 box, I seem to remember there being some other things on the memory stick when I put the stick into my lappy that are no longer there.......question is.....will the update still work by just putting the latest update onto the memory stick as normal and putting it onto my F3 ???? (or will the missing things haunt me) too scared to try updating now lmao
            • Hadron
              • Nov 2012
              • 2102
              #3006
              All you need is the TP_PROG.dbs file. Nothing else.
              • worcestersauce
                • 136
                #3007
                ok thanks for clearing that up, will do yesterdays then,
                • openup
                  • Sep 2012
                  • 51
                  #3008
                  The update AJ gave prior to the latest one had ITV1HD on which matched my picon file and epg loaded with no problem but now its gone again. Update : 13/10/14 is the one which in a long time has had ITV1HD set so as stated picon appears and epg shows up. Can this be looked at and fixed so the channel can have picon and epg.
                  • hondam8
                    • Nov 2014
                    hello all, could I ask if there are update files for the new open box v8s ..i belive they should be CFG .... is this correct ..thanks
                    • jamesndro
                      • Jun 2014
                      • 31
                      #3010
                      Has anyone converted the openbox channel list (.dbs) to a format recognised by the evo xfinity (tvdata.tar.gz)? Or is there a list from another type of box compatible with the evo?
                      • Hadron
                        • Nov 2012
                        • 2102
                        #3011
                        What are you trying to update?
                        If it's your channel list, then use the one linked to in DeejayAJ's post above.
                        • cdyscott
                          • Aug 2013
                          Is there a channel list for the Z5.
                          • bottleandahalf
                            • Nov 2013
                            • 20
                            #3013
                            UTVhd is still the old frequency in this list?
                            • Hadron
                              • Nov 2012
                              • 2102
                              #3014
                              I noticed that as well. The UTV HD at the end of the list (and the one included in the Irish list) doesn't work.
                              There is another UTV HD listed with the correct frequency.
                              • Diesel67
                                • Mar 2014
                                • 13
                                #3015
                                just used the Aj's latest channel update but i seem to have lost sky movie showcase just says scrambled my box is v8s if that helps hope someone can help me on this thanks in advance if someone can
