AJ's Sky UK Channel List **Discussion** Thread
  • mickzer
    • Nov 2013
    • 81
    #3031
    Originally posted by joe516
    My Favourites are all wrong since I loaded your list how do i fix them ?
    The way to get The favourites under the correct headings is to load the default Database:
    On the remote select Menu > Factory Settings > Select Yes > Then Press Blue (Don't make any choices at the menu)
    The screen will flash black and you will be back at the menu. If you check your favourites now they should all be in the correct order
    I wish I'd said that...
    • amar786
      • Dec 2011
      • 10
      #3032
      Anyone know when I can get a list for an Openbox Z5???
      • chippycurry
        • 36
        #3033
        Originally posted by mickmc68
        Here the list from my box in belfast UTV.HD working on it
        Mick
        tks mick will try that later
        • paul39
          • Jun 2009
          • 4
          #3034
          Well allot of people seem to be complaining about AJs channel listings it is a hard job to do ,try doing it your self you will know what i mean .
          Thanks AJ keep up the good work.
          • wxm14
            • Jul 2014
            • 63
            #3035
            anyone got the boxing on hd tonight.programme has started but not getting on hd,it is saying invalid program,search again.worked fine last week
            • makster1978
              • 118
              #3036
              do a sat search I have just found boxnation hd in all sats,ajs list its scrambled it needs editing
              • wxm14
                • Jul 2014
                • 63
                #3037
                how do you do sat search without losing aj list
                • hkphooey
                  • Apr 2010
                  • 232
                  #3038
                  How mate??
                  • makster1978
                    • 118
                    #3039
                    you wont lose your ajs channel list,go into main menu and find single satellite search and scan it once its complete click all sats on your remote and search threw all the channels till you find boxnation hd,then I just deleted my old boxnation hd in my sports catogrey and replaced it with the new one I found in the search via the edit channel if you know how to,if not just remember the channel number mines 0728,aj will sort this once he finds out with a fresh update
                    • hkphooey
                      • Apr 2010
                      • 232
                      #3040
                      I just did search and pressed end and box just rebooted !!! i have no idea what to do lmao
                      • wxm14
                        • Jul 2014
                        • 63
                        #3041
                        makster1978 thank you very much mate,just followed your instructions and have now got it,mine is on 0781 happy days.
                        • wxm14
                          • Jul 2014
                          • 63
                          #3042
                          hkphooey try it again,mine didn't reboot.or just try channel 0781
                          • hkphooey
                            • Apr 2010
                            • 232
                            #3043
                            What just type in 0781 on remote??? tried that said no such channel
                            • makster1978
                              • 118
                              #3044
                              just follow my last post the box shudnt reboot after a search just press on end logo (end) once the search as finished then go back to tv screen the hit all sats button on the remote then find boxnation hd,hkhoooey the channel numbers are different for different boxes after a search just follow what I said and you will find it,glad to help vxm14
                              • hkphooey
                                • Apr 2010
                                • 232
                                #3045
                                just follow my last post the box shudnt reboot after a search just press on end logo once the search as finished then go back to tv screen the hit all sats button on the remote then find boxnation hd,hkhoooey the channel numbers are different for different boxes after a search just follow what I said and you will find it
                                Tried it twice now bud its rebooted both times!! no idea what i am doing wrong do you??
