AJ's Sky UK Channel List **Discussion** Thread
  • singh1234
    • Aug 2009
    • 156
    #3076
    hi can we please get a new list as some zee channels hav changed frequency,thank you
    • digicon
      • 8261
      #3077
      Might be a good idea to have a look at this very informative tutorial to actually create or edit your own channel lists: http://www.digital-kaos.co.uk/forums...3-F3-F4-amp-F5
      That way you have no reliance on other members doing all the hard work for you
      • joe516
        • 1000
        #3078
        The latest CWAITE (previously sattv5) Sky Numbered Channel Lists can be found here. (http://cwaite.dyndns.tv) We now have an ALL Channels section in Favourites which contains all of the channels together (except the Non working HD channels and the test section)with no gaps, to get to this Press FAV on your Satellite Remote
        information given is to be used for educational purposes only
        Don't Forget To Say Thanks If You Like My Post
        IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
        If It Ain't Broke Don't Fix It
        • DeejayAJ
          • Feb 2012
          • 402
          #3079
          Sorry about the delay! Updated list - http://www.digital-kaos.co.uk/forums...=1#post2465938
          • vaqas32
            • 18
            #3080
            thanks for the update aj but zee tv zee cinema zee punjabi geo tv sound and picture is breaking its not clear please check it and let us now thanks
            • Hadron
              • Nov 2012
              • 2102
              #3081
              DeejayAJ...have you thought about adding a dummy channel at the end of the list that includes your name & date?
              I have heard that the CWAITE/sattv5 list now does this on channel 1 which seems like a good idea. It's a good way of double-checking that members do have the latest list installed when they have problems with certain channels.
              I tried it myself with your latest list by using the Modify > Insert function in Mediabox Editor Studio to add it to the end of the list. I had to insert it to 681 to start, then swap with 682 to bring it to the end of the list.
              On my box channel 617 on the "All" channel group now reads "AJ 30-1-15". Not much showing at the moment though. LOL.
              • fishfinger
                • Nov 2013
                • 20
                #3082
                apart from the channels listed in the last couple of post are all the rest of the channels all still working in the latest update
                all loaded only +1s working
                Last edited by fishfinger; 6 February, 2015, 18:54. Reason: just used aj chanel list
                • openup
                  • Sep 2012
                  • 51
                  #3083
                  Need an update please AJ. Could you please put in ITV1HD so XMLTV EPG shows up. Thanks
                  • hammers2009
                    • Jun 2012
                    • 106
                    #3084
                    Aj is there no new updates ?
                    • markholdo
                      • Jul 2013
                      #3085
                      aj is there any updates due im missing sky sports 2 and also sky showcase
                      movies
                      • Hadron
                        • Nov 2012
                        • 2102
                        #3086
                        movies
                        Both of those channels still working for me on AJ's latest list.
                        • samir714
                          • Jul 2013
                          hi is there any channel list for the openbox Z5?? thanks
                          • ColinsPlace
                            • Apr 2014
                            • 14
                            #3088
                            movies
                            I missing the first 4 channels , Sky premier , Sky premier + 1 , Sky showcase , Sky greats
                            sky sports 2 , have these moved frequency ? , I am using Aj's list from the last update 30 Jan 2015
                            • Hadron
                              • Nov 2012
                              • 2102
                              #3089
                              I'm using that list & all the channels you mention are still working for me.
                              Do they show as "no signal"?
                              • nuts00
                                • Aug 2014
                                • 6
                                #3090
                                Ive been using Skybox for over a year now, regularly updating the channel list. Yesterday all the channels worked after an update, and this morning, all the channels are scrambled (except freeview). This happens before but sorts it self out randomly. Is this normal?
