AJ's Sky UK Channel List **Discussion** Thread
  • Gordnil
    • Mar 2014
    • 7
    #3181
    Originally posted by Gordnil
    Can you explain how to FDA this please.
    I've had Problems with SS5 and showcase but have just flashed my F5s with CWAITE channel list and now have all channels , tried several times with AJs list ...
    • krazydude
      • Mar 2013
      • 30
      #3182
      Originally posted by Hadron
      Zing & all Zee channels still working here on 11662H.
      They are clearing, but with lot of glitches. It's as if the freq has changed and I'm quite close to the correct freq, but not quite there yet.
      • Joe Tisseo
        • Feb 2011
        • 61
        #3183
        Just Little heads up, ive used ajs list for a while now. When putting it onto a skybox f5s it bricked it twice, having never had this happen before i was stumped. Tried loading it onto a v8 and it wouldnt take it, either the file didnt take to my usb stick properly or theres an issue somewherd but just be careful if your using this list on an f5s. May have been user error but im not sure as ive never had issues with these lists on any other skybox. Anybody else have issues?
        • jondee
          • Feb 2014
          • 19
          #3184
          I always use AJ's list and never had a problem on my F5s. I even edit the list for my own preference and then dump to USB to save and it works faultlessly.
          Could be the file has been corrupted or there's an issue with your USB stick. Have you tried downloading the file again?
          • Hadron
            • Nov 2012
            • 2102
            #3185
            I have never had any problems myself with AJ's list on various different boxes, but I have read on other forums that there is a problem with AJ's list on some boxes, while working OK with CWAITE's list.
            Perhaps AJ uses a different channel editor to CWAITE? But if that's the case, why hasn't there been problems before?
            Perhaps it's due to different versions of mainboards in the boxes? (clone/genuine?)
            Whatever the reason, it's strange that it should start happening now & wasn't a problem in the past.
            • Joe Tisseo
              • Feb 2011
              • 61
              #3186
              Ive been reading that the newest firmware that is out for the openbox/skybox/libertview blah blah, doesnt like ajs channel list for some reason. Luckily the Libertview v8 im using didnt brick like the skybox f5s did, when i tried adding AJ's list. To be fair id like to try and add CWAITES but im worried i might brick the libertview aswell now! Stuck on LOAD was the issue so definatley needed re flashing.
              Just to add ive used the lists on f3 and f5 boxes for ages all with the same process of putting it on said boxes and with the same usb stick, so im leaning more toward the firmware point i mentioned above. I may pluck up the arsehole to try CWAITES list and report back.... better still if anybody else is using any of the mentioned lists with the ltest firmware on a v8s or f5s then give us a shout .
              • Joe Tisseo
                • Feb 2011
                • 61
                #3187
                UPDATE- My Libertview v8 has just taken AJs list just fine after i downloaded it again. So leaving me with 2 options, either the Skybox f5s had corrupt firmware and bricked when ajs list was added or the file was corrupt when i first downloaded it. I cant be sure as i gave thw skybox back to the seller as i found it to be crap anyway. The libertview v8 is miles better.
                • MarmiteX1
                  • Aug 2013
                  • 41
                  #3188
                  Star Plus is working intermittently ie glitches. I am using SatList from 02-MAY-2015. Is anyone else having issues with Star Plus?
                  • 9821
                    • May 2015
                    • 10
                    #3189
                    Hello, Can someoen please help..all my Asian channels are gone (b4u, B4u music, colors Aaj Tak etc)
                    • 9821
                      • May 2015
                      • 10
                      #3190
                      I am on skybox F5s
                      • Joe Tisseo
                        • Feb 2011
                        • 61
                        #3191
                        Channels on this list are dropping like flies
                          Do your own then ?
                          • Dee 121
                            • Mar 2014
                            • 9
                            #3193
                            I have been trying to get a hold of AJ for a good few weeks now. I have tried phoning him, I have tried emailing him and still no reply. Is AJ still in business. I am trying to do a bit of business with him. If you are reading this AJ, them please reply and let us know that you are alive and kickin.
                            All the best. Dee
                            • Joe Tisseo
                              • Feb 2011
                              • 61
                              #3194
                              Thanks but no thanks.
                              • Hadron
                                • Nov 2012
                                • 2102
                                #3195
                                Which channels in particular?
                                All my Movies & Sports channels (except ESPN HD) are working fine. as are all of my usual Entertainment channels.
