AJ's Sky UK Channel List **Discussion** Thread
  • Hadron
    • Nov 2012
    • 2102
    #3286
    Originally posted by joe516
    frequencies changed. Scan on 11479 V 23000
    AJ already has that frequency for BT sports HD in his latest list, so shouldn't need a rescan.
    • Hadron
      • Nov 2012
      • 2102
      #3287
      Originally posted by seangraves
      hi mate can you give us the full transponder setting and how to put it in and scan as i cant seem to find it in the tp settings thanks again i let you know how i get on ps yes blade box same provider etc works fine on there
      menu > installation > TP list. Press green button (Add). Frequency = 12633. symbol rate = 22000. Polarity = H. Save. Then follow instructions in previous post to scan.
      • seangraves
        • Sep 2012
        • 275
        #3288
        i let u no how i get on later mrs got the remote soap time
        • sickswan
          • May 2013
          • 43
          #3289
          Hi, in need of a bit of help please! ive tried numerous times to add the latest aj list but for some reason it keeps adding a previous list (17/6/15) so quite a few channels are missing. ive done everything as i normally do when adding the list so its a bit baffling. cheers
          • bullzeye82
            • Mar 2014
            • 5
            #3290
            any idea how i get premier sports on for tonights copa america game? its ?10 on sly, and free on virgin. i have an openbox
            • Hadron
              • Nov 2012
              • 2102
              #3291
              Always delete your previous channel list first. Then, if you have trouble updating with a new list, you will know straight away, as you will be left with no channels after the update.
              Delete the previous version of your TP_prog.dbs file from your memory stick before copying over the new one, or make sure that you select the option to "replace" the existing file. If you select the option to keep the previous version, then it will use the old channel list to update with.
              • Hadron
                • Nov 2012
                • 2102
                #3292
                That's something you need to ask your*******supplier.
                • sickswan
                  • May 2013
                  • 43
                  #3293
                  I've done all that, I've updated my box more times than I can remember. Cheers
                  • hkphooey
                    • Apr 2010
                    • 232
                    #3294
                    Lol ignore this
                    • martin035
                      • Apr 2014
                      • 1308
                      #3295
                      Try adding Cwaite's list and see that makes any difference;
                      The latest CWAITE (previously sattv5) Sky Numbered Channel Lists can be found here. (http://cwaite.dyndns.tv) We now have an ALL Channels section in Favourites which contains all of the channels together (except the Non working HD channels and the test section)with no gaps, to get to this Press FAV on your Satellite Remote
                      • seangraves
                        • Sep 2012
                        • 275
                        #3296
                        hi mate thanks for settings sorted on the f5s box still struggling with the skyboxf3 tried scanning tp what you gave me even deleted all channels ....no joy i did factory reset still same tried software update see if that makes any difference ,,no joy ;[ the software version on the box is 3601hd...10..05..2012...073a im getting ready ta sling it mrs wants ta kill me wen i got the remote tryin ta sort it thanks again
                        • V1lla
                          • Jul 2013
                          • 14
                          #3297
                          after applying AJ's Latest channel list to box most channels have voice over, So I added Cwaite's latest list to box and the voice over has gone.
                          Why Is This?
                            Your box prefers the later list why worry ...
                            • P&D
                              • May 2010
                              • 2684
                              #3299
                              Why Is This?
                              Turn it off with the remote settings
                              • V1lla
                                • Jul 2013
                                • 14
                                #3300
                                What button on the remote do I press then please?
