AJ's Sky UK Channel List **Discussion** Thread
  • 9821
    • May 2015
    • 10
    #3421
    Sky news HD & sky news showing "no signal" has the channel moved TP?
    • mickzer
      • Nov 2013
      • 81
      #3422
      Sky News SD on 12207 V 27500
      Sky News HD gone a while ago.
      • kaykay2471
        • Jul 2015
        • 7
        #3423
        Hello Guys.. I don't know why no one want to help me with my problem... Please please... I have skybox F3 and I can only view free channel's... I think my server if finished or something... Please can so one help me please please? Thank you all... More bless
        • P&D
          • May 2010
          • 2684
          #3424
          Yeah buddy we can help please click Here The lines in red are the ones you need to know about
          • kaykay2471
            • Jul 2015
            • 7
            #3425
            Yea sorry I click that link then I saw the rules but I don't see anything to know again... Thanks boss
            • kaykay2471
              • Jul 2015
              • 7
              #3426
              Yea I did that boss... But I can't click on the red lines.. I don't know may be because I'm using iPad
              • P&D
                • May 2010
                • 2684
                #3427
                What you are asking....to ask advice to unscramble channels is against the forum rules & also illegal this is damaging to DK question like that on an open forum leads to trouble.
                your box is working perfect as it should if the FTA channels are working.......
                The reason you are not getting all the channels ....you have answered your own question
                you know the reason why.........
                If you want them back then use Google to find what you need.......this is why your question has not been answered on DK there is NO C/S talk allowed on here
                otherwise you get banned
                P & D
                • PremierD
                  TAMINATOR
                  • Jun 2009
                  • 13239
                  #3428
                  And I second that ..........
                  • kaykay2471
                    • Jul 2015
                    • 7
                    #3429
                    Oooh Ian so sorry... I don't know all this... Thanks brother
                    • lcfc1980
                      • May 2014
                      #3430
                      Hi guys, I've never had this problem before but now when i'm trying to upgrade the channel list from AJs, when trying to select the yellow button to upgrade from .dbs all i get is "Upgrade None!". I've tried to update from my backup channel list and this just does the same? Any help much appreciated? Thanks
                      • lcfc1980
                        • May 2014
                        #3431
                        Sorry guys, me just being thick as I'm sure you know! Some sleep and some googling has cured my cretinism. 😊
                        • Hadron
                          • Nov 2012
                          • 2102
                          #3432
                          Originally posted by hanmar47
                          Help please Just updated ajs channel list but unable to get itv wales on the regional list, all other itv regions ok, is there a problem with itv wales
                          ITV Wales (& +1) have moved transponder from 10832H to 10994H 22000.
                          ITV Wales HD is now on 11053H 23000.
                          • ColinsPlace
                            • Apr 2014
                            • 14
                            #3433
                            Check internet first menu network app , go on weather & see if it's working , if that ok then check cams , if it's not visible on menu press 6666 , go in & see if active , or if it just says offline or login then yes u do require a new code
                            • 50pounds
                              • Oct 2008
                              • 36
                              #3434
                              When i upload the channels to my bros Skybox F5S (new software on) the fav menu just says Fav1 Fav2 etc etc.. it use to say like entertainment,sport
                              i have deleted all channels reset to factory settings and then uploaded the channels and it says Fav1 Fav2 Fav3 and so on so on
                              any idea how to fix this? or do i have to enter the names manually?
                              • joe516
                                • 1000
                                #3435
                                Why are my favourites not named correctly?
                                If you're using my channel list for the first time, the favourites will likely not be in order. To put them in order, go into the menu and "reset to factory settings" and then reboot. Your other settings shouldn't be effected but please backup/"dump to usb" your CCcam.cfg file first just in case anything goes wrong
                                information given is to be used for educational purposes only
                                Don't Forget To Say Thanks If You Like My Post
                                IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
                                If It Ain't Broke Don't Fix It
