openbox s10 suitable USB hard drive
  • Wingnut
    • 376
    hi lads, as im new to openbox just a quick question, does anybody no what portable USB hardrive will Defo work for my openbox s10, been reading about and some people saying that some need powered with power adapter as not much power through usb only,so if anyone has one working can they post the exact name of it, many thanks
  • camane007
    • May 2010
    • 23
    Hi , i just used a usualy Usb-drive 2Gb or 4Gb and that works well i don't need any power adapt.
    • Wingnut
      • 376
      thanks, but I was looking to use a USB hard drive, maybe a 500gb,and was wondering what one Defo works,thanks
      • slugworth
        • Nov 2011
        • 1064
        gave up
        I gave up after spending more on hardrives and external cases than I did on the receiver itself.
        Most would record sd fine but burped on hd -especially tp's with a high sr rate.
        • Passive
          • Jul 2011
          • 30
          Can you give me a channel to try as a 'worst case' example?.
          I've been using a Verbatim 250gb (Mod 47562) with no problems on SD or HD that I can see, but I may not have recorded anything on the channels you had problems with.
          I'll then give it a go and report back
          • r0nnie
            • Feb 2012
            • 27
            afaik the ones that dont require a power pack to work are the 2.5" hard drives? so try getting a normal 3.5?
            im just gonna buy a 32gig usb pen myself for 15ish quid and use that
            • slugworth
              • Nov 2011
              • 1064
              sats
              I don't think you can get the sats I use as a torture test,other side of the pond.
