s11 CCcam
This topic is closed.
  • calecadiz
    • Mar 2012
    • 4
    s11 CCcam
    Hi
    New to this and trying to get there!!!
    I am trying to get CCam on to s11 openbox going through the info from here, but when I try to dump CCcam.cfg to usb it goes through the motion but when I check it is empty. I have tried creating a txt file with the c line in and saving it to the route of the USB but the openbox will not load it.
    Can anyone help me with any pointers please
  • Dub12Dave
    • Feb 2011
    • 142
    Go to your notepad and enter the cline exactly as it was sent to you C&P if possible, save as, file name: CCcam.cfg save as type: all files save to usb
    Then put usb into usb port on back of your box,Now goto Menu -> Network Local Settings and select CCcam Plug Setting and click the OK button
    Now select Update Files by USB and click the OK button.
    Now select CCcam,cfg [CCcam Plug] and click the OK button, you should then see a check mark or tick appear, indicating you have selected the file, if there is no tick shown, then you have not selected anything, and nothing will be installed.
    • calecadiz
      • Mar 2012
      • 4
      Hi,
      tried this and get no new client and if I goo to dump the CCcam.cfg back to the usb from the box so I can mod it i get unable to creat file.
      the c line I am trying is my own as I just want to use it in a second room at home. I am using C: ip adress port user password
      thanks for taking the time to help any ideas what I am doing wrong
      • nibblitz
        • 1300
        If you're not normally seeing files extensions in Explorer, make sure you're not accidentally saving the CCcam.cfg file as CCcam.cfg.txt instead..
        • calecadiz
          • Mar 2012
          • 4
          re file ext
          Hi
          No checked and def just CCcam.cfg
          • nibblitz
            • 1300
            Are you saying your openbox wont write the CCcam.cfg to your USB device?
            • calecadiz
              • Mar 2012
              • 4
              Hi
              when i goto upgrade by usb it goes through and says upgrade finished then press info for results and it says no items found aginst CCcam.cfg
              then if I go to CCcam client set-up it says no account found.
              • DW190
                Originally posted by calecadiz
                Hi
                When its finished you should exit out and it will show saving changes. They wont be saved until exiting out.
                If you pm me an email I will send you an empty .cfg file which you can open and edit with notepad.
                • short360uk
                  • 313
                  U could just manually type it into the the box in cccam works everytime for me
                  • tshuma
                    • Jan 2012
                    • 20
                    One of the following maybe the cause.
                    1. File is set to open with notepad as the default. You may want to remove file association. It is messy but it may be worth trying first.
                    2. It may be because for host, username and password on the file are exactly the same as one that has been on the box before. So the box genuinely thinks it's the same account. I have no solution for this one yet. I have tried a factory reset and specified that only the .cfg should be erased and then tried it again but to no avail. The way to prove that it is definitely the second cause is to get something with a different username and password on the cfg file and try to read it. Your box will say new account found.
                    I would appreciate any help on the second cause because doing it manually ain't fun at all.
