Just got my S11 Box yesterday and I have to say I think the picture quality is very impressive. It's comparable with my Kathi 910 and although not quite as user firiendly in the menu systems I can see little difference if any in picture quality.
I'm having some problems with the channel editing though, I want to set up my own favourites list so I downloaded:
STBHDEditor - this seems to be a complete waste of time. You can't create, delete or name the favourites or groups it seems all you can do is add, remove or move up/down channels in an existing group. So I tried:
SetEdit HD100 - better luck with this although still not perfect. On my box I had some 20 or so groups. When I open the dumped image in the software I see only 8 groups. I can't see how to delete groups either. When I re-uploaded the image the channels and groups work but the names of the groups have not been changed.
I've read that this is common and you have to rename with the remote. However when I go into Edit Favourite all I can rename is the first group. The other groups are not listed and if I press red for 'groups' it is greyed out.
Also in SetEdit if a channel appears in two favourite groups, if you change it's position in the group it seems to get moved in any other groups it is listed in which is very annoying.
Could it be that I have downoaded a corrupt channel list or is this a common problem I'm experiencing.
Thanks,
Steve.
Thanks,
Steve.
