Dont shoot the messenger,and its suppose to be linux to!
If you want to see a picture just google!
Specifications
CA+FULL HD+WIFI
DVBS/DVBS2 SATELLITE RECEIVER
Openbox DVB-S & DVB-S2 FTA Satellite Receiver
Advantages over other receivers:
BLIND SEARCH: This receiver not only blind searches signals in DVB-S, but also DVB-S2. The Blind Search feature is very fast.
AC3 Digital Sound: Digital sound through HDMI output
Recording: Using an optional external Flash USB drive or HD, you can record your favorite shows and setup timer to do the same while you are out of the house.
EASY HH Motor control and setup. If you decide to add an HH Motor (DiSEqC 1.2 or USALS) now or in the future to move your dish, this is the best receiver available to control your motor. It has the USALS feature which makes searching for other satellites in the sky a very simple procedure.
MAIN FEATURES
Receive Digital High Definition (HD) and Standard Definition (SD) Satellite Signal
Supports DVB-S, DVB-S2, MPEG-2 & MPEG-4
Digital Video Recorder through USB (external flash or hard drive are not included)
The most affordable FTA HD receiver on the market today.
Worldwide compatible
Hardware Blind Search DVB-S and DVB-S2 (fast search less than 2 Minutes on most satellites)
Linux MIPS Operating System
STB main IC solution is ALI , demodulator model is M3501 from Ali
HD DVB-S2 SHARP 7306 Tuner
Multilingual support on screen menu (OSD): English, French, Deutsch, Italian, Spanish, Swedish, Danish, Greece, Portuguese, Finland, Holland, Turkish, Czech
Other Features
300 MHz MIPS Processor - Linux OS
Fully compliant MPEG-4 H.264/AVC Main Profile Level 3 & High Profile Level 4.1;
Fully compliant MPEG-2 MP@HL & MP@ML;
Fully compliant MPEG-1 Layer I & II & III,
Digital Audio(AC3)
SCPC & MCPC receivable from C/Ku band satellites
Multiple LNB-Switching control (supports DiSEqC1.0/1.1/unicable)
Motor Support: DiSEqC 1.2/1.3 (USALS - GoTo X)
MHEG-5
HDMI 1.3 output (HDMI cable not included)
PVR (store on USB external disk)
Multimedia files playback (by USB);
7 Days Electronic Program Guide (EPG)
Teletext and subtitle out through OSD
Multi-lingual DVB subtitle and teletext
Automatic and Manual Channel Scan
Automatic Service Scan
NIT search
Hardware BLIND SEARCH
Fast channel switching < 1 second
OSD in many languages and skin-support
Multilingual support on screen menu (OSD): English, French, Deutsch, Italian, Spanish, Swedish, Danish, Greece, Portuguese, Finland, Holland, Turkish, Czech, selectable;
LED Display
Multiple display mode: 1080i/720p/570p/576i/480p;
MPEG-2 / H.264 hardware decoding
Videotext Decoder
Analog RCA audio output: stereo (L+R);
Digital audio output: S/PDIF by coaxial
S/PDIF Interface for digital bit stream out (AC-3)
YCbCr Component Video Output
2 x Scart (RGB, FBAS or S-Video)
Screen format: Auto, 4:3, and 16:9;
Upgrade software through USB2.0 port
Powerful user interface program management function, parent lock
1x CA (smartcard reader) built-in
10/100Mbit Ethernet Interface
Notes:
No 4:2:2 out of the box (not supported)
No internal hard-drive included with receiver.
You can connect an optional external HD or Flash Memory through USB.
HDMI cable is sold seperately
Receiver Specifications
DVB-S2
Input Frequency:950~2150MHz
Loop Out Frequency:950~2150MHz
Input Level:-65~-25dBm
Input Impedance:75??
LNB Power: Auto/14v/18v/OFF, Imax = 500mA
Video decoder
Video Compression MPEG-2 and MPEG-1 compatible, H.246
Video Formats 4:3 / 16:9
Letterbox for 4:3 TV-Device
Audio decoder
Audio Compression MPEG-1 & MPEG-2 Layer I and II, MP3
Audio Mode Dual (main/sub), Stereo
Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
Output digital
Output Level 0,5 Vss on 75 Ohm
Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
S/PDIF-Output
Video parameter
Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
Teletext filter in conformity with ETS 300 472 Standard
TV-Scart
Output: FBAS, RGB, S-Video
Serial Interface RS 232
RS232 bidirectional
Bit rate 115,2 kBit/s max.
Plug Connector SUB-D-9
Function: Update of Firmware
Ethernet 10/100 MBit compatible interface
USB 1 x USB 2.0 Host, PVR
LNB power and polarization per tuner
LNB Current 500mA max.
short-circuit-protected
LNB Voltage vertical < 14V no load, > 11,5V at 400mA
LNB Voltage horizontal < 20V no load, > 17,3V at 400mA
Physical specification
Ambient Temperature +15 ?C...+35 ?C
Humidity < 80%
Size (W x D x H): 300 mm x 220 mm x 56 mm (12in x 8.7in x 2in)
Weight: 1,8 kg (4 lbs) without HDD
Power
AC auto input range:100-240VAC 50/60Hz
Consumption (Standby): Max. 10W (<1 W)
Specifications
CA+FULL HD+WIFI
MAIN FEATURES
Other Features
Digital Audio(AC3)
MHEG-5
NIT search
LED Display
Videotext Decoder
Notes:
DVB-S2
Video decoder
Audio decoder
Output digital
S/PDIF-Output
Video parameter
TV-Scart
RS232 bidirectional
Humidity < 80%
Power
