Sky box and open box on same dish problem
  • mezzyg
    • Apr 2010
    • 158
    Hello guys I've just installed a open box in my uncles house and he's got a official skybox upstairs that they use and the openbox downstairs in the sitting room
    When both on together I don't get some channels it shows 7-10% signal but when sky turned off it jumps to 75%
    Is there a way to stop this happening?
    Its a sky mk4 dish with quad lnb
    And I'm using open box s11
  • DOUGALMCD
    • May 2011
    • 3229
    Are you splitting the cable by any chance or do you have full separate cable for each box.
    Check aerial connections as well.
    • mezzyg
      • Apr 2010
      • 158
      Full seperate cables from lnb
      • Manic01
        • 5117
        There are known issues with some quad lnb and openbox.
        • DOUGALMCD
          • May 2011
          • 3229
          I would check the connectors at each end off coaxial cable first. To make sure the inner isn't touching outer. And try different output on lnb connector.
          • mezzyg
            • Apr 2010
            • 158
            Ye I se what you mean but if I change the lnb setting on openbox to another fixed number instead of default 9750-1600 it works fine with both switched on.
            If that makes sense
            • asad5150
              • Oct 2008
              • 185
              Yh i get the same problem but on other boxes the chanells work
              • mezzyg
                • Apr 2010
                • 158
                What other boxes do you mean mate?
                • souldude
                  • Jun 2011
                  • 37
                  Try changing firmware to an earlier one, this worked for me and have no problems with 2 openbox and a sly box all Hd work V & H
                  • asad5150
                    • Oct 2008
                    • 185
                    like a vu solo,vu duo and a bladebox
