S10 constantly freezing
  • irishguy79
    • Aug 2011
    • 27
    Hi guys my sis has an s10 constantly freezing. I have reset to factory settings and updated to latest firmware etc and stiil doing this,
    I was thinking maybe the tuner needs replaced wondering has anyone experienced this at all. All help appreciated
  • mast
    • Nov 2010
    • 1027
    Is this doing it on the free channels too or just the crypted channels.
    Regards
    • irishguy79
      • Aug 2011
      • 27
      Doing it on both m8 i noticed the signal bar when switching channel is ok but big bar dropping to 0 making me think its the tuner
      • mast
        • Nov 2010
        • 1027
        Could be the tuner but check the cable for soundness, no outer cabes touching the centre inner cable.
        Can also possibly be the lnb. Maybe an idea to try your box at a friends and a friends box at yours.
        Regards
        • irishguy79
          • Aug 2011
          • 27
          will do mast thanks for your help think i will try it at my gaff tomorrow and try my s9 at hers
          • DW190
            If its the tuner you will get the "No Signal" appear on the screen and the signal will have dropped to less than 50
            • irishguy79
              • Aug 2011
              • 27
              Hi dw im not getting no signal the box just freezing up on certain channels. Have tried all the firmware of the yojia site after factory reset and still doing this. Have just tried blind scanning instead of installing bouquets and failing on alot of channels, i know sat is ok as my s9 working fine of it which makes me think its the tuner. Anyone any other ideas or think what i think???
              • kevo_uk
                • Sep 2009
                • 20
                I have had the same/similar problem with my s11.
                After endless tries with dish and tuner faulty finding.
                I found the LNB to be faulty.
                As you said the s9 works fine, it could be the s10 is
                overpowering the lnb (my opinion)
                What lnb are you using?
                • irishguy79
                  • Aug 2011
                  • 27
                  my sis has a quad lnb and i just have a single lnb at my house m8
                  • souldude
                    • Jun 2011
                    • 37
                    I have spent a lot of time trying to sort this out on 4 boxes but i have gone back to an old firmware. (nov ) and i have not had any freezing or the unit locking up since i have done this. I was using that red firmware. If this works for you let me know.
                    • southpaw
                      • 2233
                      Yeh, that red fw caused my mate lots of freezing issues, swapped to an official fw an fine since,
                      On another box i had tune errors, bought a new tuner from china an that box fine since, both on s10's
                      • irishguy79
                        • Aug 2011
                        • 27
                        Have went through all the fw from yojia website direct lads and made no diff i have a tuner ordered will let you know how i get on.
                        • irishguy79
                          • Aug 2011
                          • 27
                          Sorted
                          Hi guys new tuner installed and prob fixed thanks for all suggestions hope this helps others with this prob
                          • mast
                            • Nov 2010
                            • 1027
                            Good that youve comeback with the feedback and glad your problems sorted.
                            Im sure this will help a lot of people to try a tuner.... by the way how much did the tuner cost.
                            Regards
                            • irishguy79
                              • Aug 2011
                              • 27
                              Mast i Got 1 for ?13.49 buy it now with free postage on ebay
