S11 Freeze issues
  • barrymanifold
    • May 2012
    • 6
    S11 Freeze issues
    I am hoping someone out there can help me find a solution to a problem I with a S11 box i recently bought from ebay. In fact it looks more like 2 seperate issues.
    Firstly there seems to be many channels that I cannot access, ie most Movie HD channels, EPSN, Sky Sports 3, Setanta sports to name just a few. On these channels the signal strength is only about 10% where ass all other channels that I can access the signal is over 70%.
    Secondly the channels that I can access seem to freeze for a second or 2 randomly.
    I am new to openbox setup so any advice you guys can offer would be much appreciated.
    Thanks in advance
  • short360uk
    • 313
    first u need a upto date channel list to get these channels, and second im guessing u bought this with gift so the freezin will be the server, get in touch with the ebay seller. i wouldnt buy any box off ebay with gift
    • barrymanifold
      • May 2012
      • 6
      Hi, thanks for the quick reply. I have already updated the channel list using HDS2 found on this forum. And it was just the openbox I bought off ebay. I was hoping that it was just a simple configuration issue that is causing the channels to intermittently freeze but to be honest I'm a complete newbie so could very well be anything.
      A couple of my mates connect to the same server and have no problems albeit they both have bladeboxes. It could very well be a duff box as it wasn't new when i bought it but if there is anything else that can be suggested to try I'd be most grateful
      • short360uk
        • 313
        Do ur free channels freeze also. If so then could be firmware problem if the dont freeze most likely server issue
        • barrymanifold
          • May 2012
          • 6
          Freeze issue seems to effect all channels.
          • cactikid
            • 12017
            just reading other posts of dishes gone out of alignment with the very bad weather,so maybe the dish needs a tweak or two.
            • short360uk
              • 313
              Yeah good point could be dish if affects all channels whats the signal quality like?
              • barrymanifold
                • May 2012
                • 6
                Signal quality about 74% but I've had this issue for probably best part of a week now.
                • short360uk
                  • 313
                  Dump ur cline and try a firmware update, use the annymous clone safe see of that solves it, if not maybe tuner problem
                  • barrymanifold
                    • May 2012
                    • 6
                    Sorry for being a complete spanner mate but I have no idea what the above post means. I should also have advised that I'm in need of educating as well
                    • short360uk
                      • 313
                      U will have to save ur cccam.cfg file to a usb, u will have to google how to do this cos it might be comin close to breakin forum rules. Once u have it saved reflash u box with clone safe firmware, all can be found on the forum. Check out shady's tut it will tell how to do it
                      • barrymanifold
                        • May 2012
                        • 6
                        Cheers for the info mate. Gonna hit the sack just now and try angain tomorrow or I'll end up sitting here all night again.
                        I'll let you know how it goes
