stb memory error on skybox f3
  • nikskyboxf3
    • Jan 2013
    Originally posted by partage
    It worked for me too. Thank you slugworth.
    you can use the latest firmware from here:
    Skybox F3/M3 Software-USB Wifi(120920)_Shenzhen Yojia Technology Co., Ltd.
    Don't forget to check "include bootloader" in the loader.
    thanks for firmware i can use.........
    • Satellite Receiver KING
      • Feb 2013
      #17
      I'm trying to help my customer to solve this problem
        • Feb 2013
        #18
        some copy skybox still can not update
        some copy skybox still can not update wthis problem can not resolved, need original cheapset.
        • kikoyem
          • Aug 2011
          #19
          tested with this
          • kikoyem
            • Aug 2011
            #20
            Originally posted by slugworth
            tested with this software for F3..it's worked G R E A T ! ! !
            Others upgrade tools got error, might be the memory size setting error!
            • slugworth
              • Nov 2011
              • 1064
              #21
              the eromclient.abs file has to match the processor in the receiver or you get the error.
              some loaders have 3 or 4 versions of the file.
              • bennietriest
                • Jun 2012
                #22
                Solution
                I was close giving up the fight but did not with success. Trust me... buy the right rs232 null modem cable. I tried 2 other ones and was sure it was not the cable that was wrong. IT WAS and I was wrong. my m3 is working like a dream. and I wont load 4000 channels again.
                • tshuma
                  • Jan 2012
                  • 20
                  #23
                  I have just tried mine using this and it's responding already.
                  • slugworth
                    • Nov 2011
                    • 1064
                    #24
                    4000 channels? even if you just spent 30 seconds on each channel to see what was on, it would take you 33 hours to go through each channel.
