Subtitles on S12
  • nr7medost
    • Feb 2012
    • 16
    Subtitles on S12
    Hello all.
    i have 1 openbox s12, and its new did not made any update or any thing, dont know what to use or how to do it right now
    but there is one problem, if a channel like tv1000 has 5 diferent subtitles (sweedish, dansih, romanian ect) and you choose danish, the next time you will watch this channel it dosent remember the language you previous has used
    how to make it remmeber it so i dont have to change it every time i change channel
    hope someone can help
  • bluelascalla
    • Nov 2011
    Same here. S9. Is there a way to set default subtitles by your choice that will not change after switching channels? Thanks.
    • slugworth
      • Nov 2011
      • 1064
      language menu?
      • bluelascalla
        • Nov 2011
        Bulgarian language. But is there any difference, I can use English as well. The primary subtitles on some channels are in Romanian language. I change them to Bulgarian but when switch the channel and then back it's Romanian again.
        Basically, is there a way to delete Romanian language from subtitle button menu, so Bulgarian subtitles become default. Thanks.
        • slugworth
          • Nov 2011
          • 1064
          the language menu has the teletext choice of language.
          try setting that.
          • bluelascalla
            • Nov 2011
            Unfortunately, it didn't help. Well, I guess I'll have to select the subtitles I want manually.
            • slugworth
              • Nov 2011
              • 1064
              I don't have any channels with subtitles where I live,so I can't play around with it.
