uh? you are naming the file TP.Prog.dbs it need underscore between the TP & Prog and not a dot TP_prog not tp.prog
BEST Sky UK Channel List 100% same channel numbers
I notice the original post was done some time ago. Will it have the latest Sky channels,Olympics etc, or does it not update automatically?
I love AJ's up to date channel listing but the idea of the corresponding Sky channel numbers really appeals.
Thanks in advanceComment
hey rodrygas any chance of an updated list as there has been many changes since your last one? cheers your work is appreciatedComment
I will second this. I would def use this list if it was up to date. I'm not sure what I'm doing when updating changes through transponder settings so a new list would be very much appreciatedComment
How do i get the Asian channels to work, Kind Regards..... Tutorial on how please will be much appreciated.As title this is a UK Sky Channel List for all Openbox's. This list has the exact same channel numbers as SKY UK eg 101 BBC Once, 106 Sky one, 520 Discovery etc. Asian channels aren't to order as I never watch them.
Suitable for openbox and anybody S9 S10 S11 and S12
How to add list
***65279;Below is from Shady's sticky.
1: Copy contents (TP_PROG.DBS) of downloaded file to USB drive formated to fat32
2: Press Menu on remote, and highlight
"TOOLS"
3: Select'Upgrade by USB'
4: On new window, use arrow keys to
change top line to 'MISC FILES'
5: Move down to 'SELECT AND UPGRADE' |
6: A new window opens, select
TP_PROG.dbs' press green button to place
a tick by it and then press yellow button
to upgrade
7: If the box asks anything just press yes.
Any problem please let me know so I can fix. If you like this then please hit thanks.
Thank you in advanced.Comment
Hi mate...They r saved in Favourites under Fav. no. 11 named as "International" and to de-scramble the paid channels, u will need a cline or nline to add in ur box.U can get it from any cardsharing website. Hope u know wat is c-sharing...if not u can search on this forum and on google..there is plenty of info available.Comment
all channels are messed up, if i select music on favourites i get number 1.sky 3d
2. sky sports news etc...
does someone have a working correct list for a s11 ??
thanksComment
