Openbox or Skybox Wifi?
  • wurz
    • Apr 2010
    • 123
    Looking for a wifi solution to these boxes:
    Skybox F3
    Openbox X3
    Openbox s11
    What options are out there?
  • seanmckeown
    • 206
    F3 has wireless option and U can use a usb WiFi adapter.
    S11 requires a WiFi bridge such as the vonets one
    • northern2012
      • Jan 2012
      • 5
      i use openmedia wifi bridge but if i use it in the usb port to power it then it drop connection sometimes. so i use usb power adapter and had no probs at all
      • canford
        • 263
        If you go for F3 you will have wifi adatptor sticking out of front of box, no usb on back!
        • slugworth
          • Nov 2011
          • 1064
          record
          Originally posted by canford
          If you go for F3 you will have wifi adaptor sticking out of front of box, no usb on back!
          which is a lot easier to get at,but you can't record at the same time since there is only 1 usb port.A serious flaw.They should have put support in for a usb hub instead.
          • jhonnyb
            • Jun 2012
            • 21
            I am having probs on WEP on F3 - still waiting for software update - invalid key length problem
            • kaisar1
              • Aug 2009
              • 462
              that is because on your router you more than likely got wep/wpa2 password. you have to choose one encryption method. wep or wpa or wpa2. you cannot have a combination of both
              • r1dave
                • Nov 2011
                • 35
                wifi
                you can use tenda w150m. i have one, very stable. ive also had it tetherd to my mobile phone when in the caravan, very good little device.
                • paulrodgers7
                  • Sep 2012
                  I have on openbox x3 with a skybox official wifi dongle (non aerial type) i have tried a few combinations of encryption but it still fails to connect........ I`m not giving up though
