Freezing on channels on F3
  • spdude1
    • Jun 2012
    • 81
    Hi,
    Just got a Skybox F3 and been noticing that certain channels keep freezing every now and then. I called the vendor and he said that he has refreshed the connection (whatever that means) and it should be ok..and it was till yesterday night...today morning its doing it again..!!
    I am connected to the net via the official Wifi dongle. Could it be that the dongle is crappy and should I connect the box with a ethernet cable and see if it makes any difference or something else could be wrong..??
    May its just me but seems that the HD channels (shy movies) seem to freeze more comparatively..!!
    The quickest way to double your money is to fold it over and put it back in your pocket..
    Originally posted by spdude1
    Hi,
    Give it go hard wiring it you have nothing to lose,it may improve and you can let others know..........................
    • gingeee85
      • Jan 2012
      • 197
      id try the hardwire matey but also depends on your provider, mine my sly movies do them same on a s11 sometime lose them completley
      • kaisar1
        • Aug 2009
        • 462
        mate i doubt it has any thing to do with dongle, worth a try a try hardwiring.
        got a feeling its more to do with provider.
        • wesleyscott88
          • Jun 2012
          Im having the same problem tried hardwiring. wifi. and hotspot on my phone still not working properly is there any settings i can try on the box ?
          • kaisar1
            • Aug 2009
            • 462
            mate is the receiver connecting to the internet when hardwiring?
            turn dhcp on and of. play about with network setup.
            What router have you got? and who is your isp?
            • kaisar1
              • Aug 2009
              • 462
              heres my settings- 02 bb
              dhcp off
              ip address 192.168.001.085 (can be any number on the end eg 100)
              subnet mask 255.255.255.000
              gateway 192.168.001.254 (your router ip address)
              dns primary 192.168.001.254 (same as gateway)
              dns secondry 192.168.001.001 (same as gateway except for last 3 digits)
              try copying my setting except for gateway change to your own router address.
              • spdude1
                • Jun 2012
                • 81
                dhcp off
                Thanks for sharing but if I dont have a static IP..i am guessing you do...if I switch DHCP off will it still work..?
                • wesleyscott88
                  • Jun 2012
                  Thanks kaisar1 sorted it out now with your settings seems to be working alot better now
                  • avd
                    • Feb 2013
                    • 20
                    Hey guys I would also like to change settings on skybox dhcp.
                    I know my router ip is 192.168.0.1 so I know where to put that. I am a little confused what I enter for secondary dns 192.168.0.? Do I just add any number? Or do I get that info from my router?
