Strange HDMI issues with SkyBox F3 + Sony Amp
  • briz
    • Jun 2012
    • 38
    Hi all,
    Using an F3 with firmware 3601HD_08_05_2012_0781
    Following my quest to get 5.1 DD sound over HDMI from my Sony Amp I've discovered some very strange issues with HDMI interaction between TV & AMP whenever the F3 is connected.
    I have a Panasonic Viera Plasma (TX42GT20B)
    I have a Sony Receiver/Amp (STR-DH810, also tried the 820 with same issues)
    Basically, whenever the F3 is connected I lose the Audio Return Channel (ARC) and HDMI control that normally exists between the AMP & TV. This allows me to use a single remote to control TV + AMP with synchronized volume, switch on/off etc and also get the TV audio through the amp without an extra optical cable, so it's very useful.
    Reproduced 100% after several connect/disconnect. With F3 connected I lose this. Disconnect F3 and reboot everything and it works again.
    Tried plugging F3 directly into TV and using ARC for audio back to the amp, but I lose dolby digital surround this way since the TV down-mixes it to Stereo LPCM 48. There's no optical/coax digital audio output on the F3 so this isn't an option either
    Anyone else seeing similar issues and/or have a solution to this?
    Thanks for reading!
  • singingshiver
    • May 2012
    • 12
    Originally posted by briz
    Hi all,
    Thanks for reading!
    Ive got the exact same thing. Panasonic Viera TV with Panasonic Surround. No solution found.
    • cactikid
      • 12017
      have another look at back of box.
      Digital audio output: S/PDIF by coaxial and optical;
      looking at the image of box black socket between rs232 and power switch looks like a phono connection which is a digital out to amp.
      the way i hooked up my stuff is tv to sat box i used hdmi and spdif or digital out from box to in on amp to give me 7-1 sound,i have an onkyo with loads of places to insert plugs.
      • deadlyminimee
        • May 2012
        • 14
        That connection is a 12v output for something. I am trying to connect my F3 to surround using digital coaxial but can not see where it would go!!!!
        • cactikid
          • 12017
          silly question any drop down front flap?do you have the booklet that came with box to see what specs it says,for boxes nowadays not to have a digital out port is silly
          • briz
            • Jun 2012
            • 38
            Thanks for posting, at least I now know it's not a specific fault with any of my kit. Guess it's down to the TV since we have different brand receivers.
            • briz
              • Jun 2012
              • 38
              There is a flap, but only OSD controls, USB & CA slot in there. I know all the specs online for these boxes list optical & coaxial digital audio out, but it's just not there! Only way is over HDMI
              • cactikid
                • 12017
                they should not have said spdif and digital coaxial out in advertising the box should have at least one,have you tried a better hdmi cable as some dont.
                • marsellus
                  • Aug 2012
                  • 13
                  HI Guys
                  Spent few hours to find out whats the problem before i found this forum and info.
                  I got
                  Panasonic 42gt30, Yamaha RX-V671
                  After connect SKyBox F3 thru hdmi and amp i lost ARC, Viera link control to amp.
                  I setup Hifi every day at work so i think cheap chinese box is not compatibile hdmi out and blocking amplifier and other devices to talk over hdmi.
                  Got no solution for that and firmware wouldnt sort this problem while its hardware problem inside skybox.
                  Only way is to change to dm800se what i done and its fine
                  thanks.
                  • satmanuk
                    • Aug 2012
                    ive got the same Problem running Sony DG820 amp with Sony Bravia TV, lost my sync vcontrol while F3 is connected - hope there is some sort of fix for this sometime, its a right PITA
                    Running Scooby firmware
                    • cactikid
                      • 12017
                      only fix may be a better box,if makers dont give a spdif or digital co ax out box cant give 5-1,now if you had a big amp and connected the hdmi to that who knows??
                      • satmanuk
                        • Aug 2012
                        I picked up 3 Port HDMI Switch Box Switcher Selector Splitter 1080P | eBay today as I was running a Sky amstrad looped through from a SkyboxF3 and the switcher seems to strip out the offensive signal that blocks the Sony Amp control, so good news.
                        • smokinweed
                          • Mar 2013
                          Hi all,
                          Thanks for reading!
                          panasonic tv and panasonic sound bar and panasonic blueray dvd player
                          all interlinked perfectly with my tm800hd ( could only get 720i ) so I bought skybox f3
                          no matter where I put f3 it stops everything synking
                          tried it in all hdmi's in tv and all in sound bar ( obviously not the arc's) and even tried a 3 port hdmi splitter in both the tv and sound bar ( every combination possible )
                          gonna try an optical cable this afternoon and try another f3 too
                          my head is cabbaged
                          • vipulan10
                            Skybox F5 with Sony amp & TV
                            I have the same problem where connecting the box stops the Bravia Sync. Still no solution?
                            • cactikid
                              • 12017
                              there probably never will be ,a budget box and missing a spdif or digital coaxial out for 5-1,next upgrade hopefully it might be on them.
