skybox f3 error 1 ?
  • venza1
    • May 2012
    • 54
    skybox f3 error 1 ?
    has the title says ppl my friends skybox f3 loads to 0093 then freezes for a while then the display says error 1 , is it a firmware problem ? any help on it would be brill ...
  • spdude1
    • Jun 2012
    • 81
    have u done any firmware updating lately.?
    Or it just popped up by itself one fine day..??
    The quickest way to double your money is to fold it over and put it back in your pocket..
    • venza1
      • May 2012
      • 54
      poped up itself m8 hes only had the box 2 weeks the fella he brought it off said he would install latest firmware and channel list but when i checked it it had a few channel missing so i installed my channel list, thats all that has been put on the box m8. it started acting up 2 days ago
      • spdude1
        • Jun 2012
        • 81
        Did you take usb dump before putting your channel list..?? and if you did...did you try updating the box with that dump files..?
        • venza1
          • May 2012
          • 54
          nope m8 all we did to my friends box was just updated the channel list our side that was it really.
          i have 1 also off the same guy i havent had any probs with mine tho .
          • spdude1
            • Jun 2012
            • 81
            Even if you flash a new firmware..you might loose your gift...I guess the best would be to ask the seller to send you the files and upgrade with that and see if the box comes back to life. Assuming you did everything by the book when loading the channel list...it might be a hardware issue...but again the best bet would be to get back to the seller
            If it does come back to life...pls save a dump first before loading any channel lists.
            • venza1
              • May 2012
              • 54
              ill do a back up of everythink then try the firmware update see what happens ill message the seller first tho , thx for the help anyways m8
              • venza1
                • May 2012
                • 54
                tried the new firmware update worked turned off restarted etc but then when he woke up this morning same again error 1 ? ive advised him to chat to the seller about it
                • spdude1
                  • Jun 2012
                  • 81
                  That seems to be a prudent option
                  • SECURESIGNAL
                    • Jun 2012
                    HI can some one help me I can find the password for my skybox f3 I have try many password ( 6666 ; 8888 ; 1111 ; 0000 ; 1234 ; and no luck
                    • spdude1
                      • Jun 2012
                      • 81
                      Password for wat..?? if its for the channels then you got to get in touch with the person who sold you the box..or if you updated your channel list yourself then check the thread where you downloaded the .dbs file from...
                      Hope this helped..!
                      And yeah...you are likely to get more response if you start a new thread instead of discussiong a new topic in someones elses thread..!!
                      • ahkam05
                        • Jun 2012
                        Any luck guys? Mine also facing the same problem..please help?
                        • lincsat
                          • 1228
                          It sounds like a firmware problem. Try loading stock firmware by RS232 then do a full reset.
                          • hayd0n
                            • Jun 2011
                            • 161
                            SECURESIGNAL try 3312 3313 . i agree with lincsat r32 had a smiler prob my self i have the original sofwear if u need it
                            • hayd0n
                              • Jun 2011
                              • 161
                              SECURESIGNAL u could r32 your and load new sofwear to by pass the password
