no signal
  • anno 1366
    • Apr 2010
    • 272
    no signal
    hi, a bit of info needed,.when i turn on s10 all ok,
    then gradually audio starts to break up but picture
    ok ,then picture starts to freeze and glitching .then
    you cannot use the remote or manually change
    channels,then no signal,
    have checked with server all
    ok there and checked all connections,box is approx
    9 months old ,this happens on all channels and freeview
  • kabiela
    • Jun 2011
    • 10
    put another new software on your S10 openbox
    Also consider new and load channel list it
    do you have in your network are also dhcp
    • spdude1
      • Jun 2012
      • 81
      If its messing up on the freewviews as well then mostly its not the server or internet connection issue. probably a software prob and hopefully not a hardware one..!!
      The quickest way to double your money is to fold it over and put it back in your pocket..
      • anno 1366
        • Apr 2010
        • 272
        yes my supplier says it may need s/w update,
        at the mo its gone back to all ok
        • anno 1366
          • Apr 2010
          • 272
          all sorted ,new s/w update has
          solved problem thank for advice
