trouble setting up
  • Greg680
    • Jun 2012
    • 7
    trouble setting up
    hi guys having a few problmes setting up my openbox hd11 i input all the information correctly an its status is still offline so i have been told to turn off the DHCP but when i try to apply it it says invalid alternative DNS
    what should i do?
    please help
  • mast
    • Nov 2010
    • 1027
    Whats your set up, I always keep dhcp on. Are you saying you cant get payview channels.
    Regards
    • Greg680
      • Jun 2012
      • 7
      the DHCP is on at the moment but if i look at my line set up it is ticked for active but says offline
      • mast
        • Nov 2010
        • 1027
        Then either you have not inputted details correctly or problem at server end.
        Also what is your setup direct cable or homeplugs.
        Regards
        • Greg680
          • Jun 2012
          • 7
          in the tools part there is a factory default should i do that an see if i can start again from fresh?
          • mast
            • Nov 2010
            • 1027
            At this stage I wouldnt, if you do factory default make sure you have made a full dump before you mess about and also you have the all important details saved.
            Regards
            • Greg680
              • Jun 2012
              • 7
              not 2 sure what you mean by a dump or what there is to dump because i havnt even started to watch anything coz it aint working
              • mast
                • Nov 2010
                • 1027
                Ive just sent you a pm.
                Regards
                • mast
                  • Nov 2010
                  • 1027
                  Are you getting any channels at all, the freeview.
                  • Greg680
                    • Jun 2012
                    • 7
                    watchin bbc3 on it at the moment
                    • mast
                      • Nov 2010
                      • 1027
                      Replied to your pm, you need to check setup your end, cables etc. Has your box been assigned an Ip addy and as you have your all important info you could update firmware and channel list if you want.
                      Regards
                      • Greg680
                        • Jun 2012
                        • 7
                        totaly new to this so not 100% on what ur on about
                        • mast
                          • Nov 2010
                          • 1027
                          Just sent you a pm on how to input info try that and see how you get on, think you may have missed something inputting via remote.
                          In your menu you can see your network details cant you cos in some firmware I think its been greyed out.
                          Regards
                          • mast
                            • Nov 2010
                            • 1027
                            Glad you are sorted now.
                            Regards
