Opebox 11 'No signal' on certain channels
  • Red D
    • Jun 2012
    I bought an openbox11 with all the channels already installed.
    However, some are showing 'no signal' (i.e. Sky Premier, yet Sky Premier+1 works fine?), Sport 1, 2 & 4 work, yet Sports 3 has 'no signal'
    Would installing a new channel list solve the problem, or is there anything else I can do to fix it?
  • cactikid
    • 12017
    channels have probably moved giving you a no signal,you could rescan to get them working again,if there is a new updated list that could be used also.
    • Red D
      • Jun 2012
      cheers
      think ill try this first No Signal Fix for Openbox s10 s11 Skybox s12 V Polarized channel selection | eBay
      • DOUGALMCD
        • May 2011
        • 3229
        I have to agree with cactikid. Anybody would have to try a rescan first especially as this would be the easiest option and free.Then check all cable connections and lnb. This thread sounds like someone trying to sell me something.
        • khady
          • 5
          hi
          some channel will move to diffrent frequacy so your best choice is scan the box if this does not help get your dish checked if it moves slightly with wind that can cause is well
          khady
          • termiantor
            • 400
            change your lnb all will be fine
            HAD THE PARTY LOL
            • souldude
              • Jun 2011
              • 37
              There are different ways to try.
              i installed an earlier version of firmware and never had a problem since on 10 boxes.
              no need to change lnb ( unless it is a very very old one )
              that fix off ebay never worked either for me
              another one is do make sure your cable is in good shape, no water coming down it as i have seen being an installation engineer over the years.
              • DeejayAJ
                • Feb 2012
                • 402
                I'd say a channel list update will almost certainly fix it, why would you try anything else first? It's free & takes about 2 minutes.
                • termiantor
                  • 400
                  i think youll find there is a need to change the lnb
                  some openboxes are very fussy with quad lnbs
                  and if he changes it all will be fine (please post back when
                  u get your solution)
                  HAD THE PARTY LOL
                  • scottyfogg
                    • Jul 2012
                    Im also having the no signal problem :$, will try and download the channel list see if it fixes the problem
                    • scottyfogg
                      • Jul 2012
                      Problems!
