Problems Tenda w150m to openbox
  • mini
    • 602
    Got problems trying to connect Tenda W150m to openbox. Followed the instructions from goldwaffer and still no joy. The box works fine with ethernet cable, just this tenda w150m causing problems. Any and all help appreciated, thank you.
  • Shady
    Shite Link King
    • Dec 2010
    • 6404
    does the tenda work on any other ethernet enabled equipment? xbox etc? when you say not working, do you mean channels not clearing? can you see the openbox in your network?
    • mini
      • 602
      I tried the tenda on my laptop and still never got to connect to internet.
      Sorry, the channels are not clearing on the openbox. i've followed the guide on youtube and still no luck.
      The router has WPA encryption.
      • Shady
        Shite Link King
        • Dec 2010
        • 6404
        i have one myself and it worked first time after following set up on goldwafers.. can only assume youve either done something wrong, in which case, try again or you have a faulty unit
        • mini
          • 602
          would it be best if i change the router access code to wpa2 and hex and try it all again?
          the router is from sky, would it make a difference...
          Managed to get it working on pc somehow, had to change somet in wireless options.
