try fuse 1 amp they go easy , if not just lift the power lead up and down gently by the input into the box as its switched on, i had the same thing ages ago , tried everything then as a last resort just did that and it worked , booted up and only happend once since.
bingo mate got it on cheers with the power lead up and down
