motorised channel list openbox s11hd
  • appymcfc
    • Jun 2012
    • 10
    Hi anyone got a motorised channel list i can load on this receiver please
    Regards
    appymcfc
  • nibblitz
    • 1300
    You'll be best to scan and sort your own, as only you know what satellites you actually want.. Remember, you can only store 5000 channels, so work out what satellites you personally want, scan one sat then sort and delete channels you dont want, then go on and scan the next satellite.. If you go off and scan half a dozen satellites all in one go you'll quickly run out of channel space..
    • appymcfc
      • Jun 2012
      • 10
      thanks did that already and ran out of space but when i scanned i did not pick up all the channels on each sat that i ought to have i tried blind and accurate scan
      i will delete channels and compile the lists myself thx for the reply
      • darcu5
        • Jun 2011
        • 944
        For the missing channels you will have to check the transponders for the the missing channels on kingofsat.net then manually add the transponder into the box and scan it...
