ok the vonets wifi bridge works on the laptop im using it now, but not on the skybox f3 why i have installed new firmware with wifi that shows up and i select that but wifi manager not highlighted do that mean something wrong with th bridge or the firmware or what /
vonets wifi bridge!!
Tags: None
i dont think it works on the f3. I havent tried myself but near sure i read somewhere that it doesnt work.
If im wrong and it does work, it would work if u have the wifi manager switched on, just go into network settings and change from ethernet to wifi then restart the box -
May be there is a specific Vonet wifi bridge for each brand of sat reciever. Contact seller.i dont think it works on the f3. I havent tried myself but near sure i read somewhere that it doesnt work.
When I bought , my vonet, I specified it should be compatible with all DM boxes( mainly Dm 800 Hd and Dm 800 SE HD/SR4). The right type was posted to me.
WElcome other observations aboy VONET. THNKSComment
i tried that but after selecting wifi and reeboot it didnt allow the wifi manager,unable to selecti dont think it works on the f3. I havent tried myself but near sure i read somewhere that it doesnt work.
If im wrong and it does work, it would work if u have the wifi manager switched on, just go into network settings and change from ethernet to wifi then restart the boxComment
have sent back now but will msg him saying what its for thanks,could work but i downloaded the software of the official site but as i said above the wifi manager was there but unselectable,which makes me think something to do with the channel list/firmwares...however i set up on a netbook which it works on that ??May be there is a specific Vonet wifi bridge for each brand of sat reciever. Contact seller.
I use a usb wireless n adaptor. Was only ?7 on eBay locally. Can get them from china for ?2.50 eachComment
WIFI 150MBPS WIRELESS ADAPTOR 802.11 B G N LAN NETWORK MINI USB DONGLE ADAPTER | eBay
Thats the usb 1 i use in F3 nd X3 openboxes
MickComment
How stable is ur one mick? The one I use has an antenna and it shows as 80% in the floor above the router. Was just wondering, as ur one doesn't have an antennaComment
ok im in the exact same boat , bought a SKYBOX F3 and gonee through all the set up with scooby snacks FW. I tried the Vonets WIFI on the pc and worked fine.
I then tried it on the SKYBOX altering all the settings but the "WIFI SETTINGS" set up page is greyed out and i can't select it to add my wireless network details.
does the vonet work with a SKYBOX F3 ?
Has anyone got it working ?
And if so , how ??
, its going back otherwise.Comment
Hi Guys,
I had this problem I couldn't get it the vonets to work, my laptop found the vonets, highlighted it, pressed next but it wouldn't find my network, after much head scratching I finally went into my router settings via a web browser and realised that my router was using auto channel 13 (but the vonets only goes to 11) I changed the channel to 10 and bugger me it solved it.
I hope this helps, it maybe the same issue?Comment
Guys,
for all of you having trouble setting this up remember that this is an ethernet bridge & not a wifi adapter so turn off wifi & change network connection to ethernet enabled instead of wifi & it WILL workComment
