Ok, i have two skybox s12`s and one is at my current address and the other is at the parents. we both have clines from the same person and we both use the same firmware. Problem is that we get constant freezing. I have a dreambox as my main box and this is picture perfect to some degree,give or take a glitch or two. So the question is, does anyone have an original openbox s12 that is stable enough to watch and if so, which firmware and bouquets do you use or should i use. This would be a great help because there is not a lot of support on these compared to the dreambox and if someone is running more or less glitch free then that will do for me and probably aid others who are experiencing the same problem. Just hope someone is lucky enough to not have this problem and help.
